Problem with y-joint pipes
 1-13  14-22
10104.14 In reply to 10104.13
Indeed! :)
You have not made the internal fillets but seems they work also fine!
10104.15 In reply to 10104.14
hi frency,
just a fyi
on the last video you show, of the interior fillet. it's going to a point. that's not realistic. no process would have a point there. it would have to be some other shape. preferably a smooth one, lol.
10104.16 In reply to 10104.15
@Anthony
Sorry i don't know about what point do you speak ???
I have truncated 2 branches for more easy understand what is the internal Fillet
Before Fillet
After Fillet
After Fillet
Before Fillet
EDITED: 11 Jan 2021 by PILOU
10104.17 In reply to 10104.16
hi frency. the last pic. where all three fillets go to that point. i'm not sure that is realistic. i'm not an expert though. put points in fea cause stress concentrations. in real life parts fatigue failures. from a manufacturing point of view, i don't think it's possible to create a point or a straight edge for that matter. CAD takes a lot of liberties. not sure what the op is trying to do though. it's an esoteric thing. not sure if it's relevant here. but something to watch out for if you are building real things.
Say you are in Pipes better for have better flow no sharp singularity! :)
(water, wind, gaz, etc...)
It's for that i fillet the internal parts! :)
We are in 21 th century! ;)
Smooth is beautiful! :)
like this one
10104.19 In reply to 10104.17
hey frency,
i don't have moi v4 yet. but i used the cad program i have. i built a similar model and it looks like that works out to be tangent. so it's probably fine. in the pics and videos it looked like it was sticking up. just a visual thing i guess.
10104.20 In reply to 10104.19
In fact the Fillet (external, internal) are dependent of the thickness so it can take measures inside a range more or less possible...so more or less tangent...
10104.21 In reply to 10104.20
i tried to take pictures of it, but couldn't get a good angle. but basically it looks like three circles coming to the same point. so i think it would always be tangent in that case. but viewing it in cad, at various angles, it looks messed up. you can only see it's tangent from a side view. as soon as you rotate off a little, it looks like the fillets are rising up to a point. it was pretty challenging to make. it made me wonder if there is an n-gon patch in mecway. i tried to do something a little more like what i was thinking, but couldn't patch something that complex.
so with that pipe model. if you put a cylinder through the center and cut out a circle. then fillet everything. then try to patch the holes. that's what i was thinking was going to be needed. fortunately, it wasn't that complicated. just the fillets seem to be ok.
10104.22 In reply to 10104.21
yes it's very curious that is very hard to give a tickness to this simple surface! :)
Show messages:  1-13  14-22
