Grid modelling
All  1-3  4-9
Make a "Flat" one then use the Flow function for "project" on any target volume's surface! ;)
Will work of course also with start "surfaces","volumes" ! ;)
EDITED: 7 Jan 2021 by PILOU
10102.5 In reply to 10102.1
Hi andrzejgdula, generally something like that is better to do as a texture map or shader inside of a rendering program rather than modeled as actual geometry.
If you did want to model it then probably building a flat pattern with some sweeps and then using Flow like Pilou shows above would be the easiest way. There is some more information on Flow here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
Here is a machinist type reference, likely with much more information than desired :-)
http://www.reed-machinery.com/wp-content/uploads/2019/04/knurls-and-knurling-tech-data-master.pdf
I think that if a person is going to boolean away the "grooves", that their size must match up with the circumference, to avoid a discontinuity...
It looks like some of the tools move the metal, rather than machine it away...(probably not a desired CAD method.)
No more time to play today.
10102.7
Something I was working on in the Node Editor a while back.
EDITED: 17 Jan 2021 by WAYNEHILL5202
10102.8 In reply to 10102.1
try this.
Create star shape in custom mode and extrude.
Add a twist then mirror object and boolean union.
Barry
10102.9
Show messages: All  1-3  4-9
