Hi Hans,
> Even though I still don't think I understand why there is no surface like you stated?
I meant that in your post you showed this:
Were those meant to be planar cross-section surfaces? Those are the ones you don't have in your .3dm file. But it sounds like there is a Grasshopper method to generate those for you automatically?
> For a calculation of the center curve I am thinking of first slicing the tube/solid/shape in little pieces.
> Then find the midpoint for each piece by integration. Then connect the midpoints to a single center
> curve and finally smooth out the edges if need by some smooth algorithm.
Sounds good - I thought that you were asking for a fully automated calculation.
> Yes exactly - well a bit of both. My idea is that I can cut out an interesting shape and then change the surface on that shape
Ok, but to get a tube like that another approach that would be simpler could be to project just one curve onto your solid and then sweep with that rather than cutting out a channel with 2 curves:
For example, just one profile curve:
Construct > Curve >Project to project it onto the solid:
Construct > Sweep using the projected curve as the rail curve for a one-rail sweep:
