Modelling a Böbbel
 1-15  …  56-75  76-95  96-99
10096.96 In reply to 10096.92
First create a solid of the larger ring, with its gap.
Second, sweep the small circle to 100% of the gap, and close its ends, to make a solid.
Boolean union the two solids. Result is one ring with smaller diameter in previous gap. Delete or hide the curves. Use the edges to fillet.
Fillet the 4 edges. Total available radius to fillet is 7.5mm - 6.5mm = 1mm,
so the sum of the inner and outer fillets should be at most, 1mm.
10096.97 In reply to 10096.95
Hi Lara,
> I only want to understand why the filleting failed at sweptAtOnce version..
Yes like Phiro writes above it's the same answer from earlier in the thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10096.34
Filleting is only possible at edges that are sharp, not at edges that are smooth (tangent) where surfaces meet up.
Additionally, you would need to have an edge between 2 different surfaces to make an edge fillet, if you delete your curves used to generate the sweep you should see that your sweep generated a single large smooth surface.
> It is a sweep with only circles. Do not know why the generated geometry has soft edges.
Because that's how sweep works, if the path for the sweep is smooth you get a smooth surface generated from it. Sweep will only make a sharp cornered shape in places where the path curve also has sharp corners in it.
10096.98 In reply to 10096.40
Hi Pilou, How did you get that shiny material preset for your objects in MOI?
10096.99 In reply to 10096.98
@Subroto
Take a look at this thread ;)
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5222.47
And sometimes before send the image i make some corrections colors in any 2D prog
mine is an very old one (more 20 years old : Photo impact 6 :)
If you want a free cool one for some drawing/painting effects take a look to the free FotoSketsher (made by a French guy! ;)
https://fotosketcher.com
EDITED: 2 Apr 2021 by PILOU
Show messages:  1-15  …  36-55  56-75  76-95  96-99
