Modelling a Böbbel
 1-15  …  36-55  56-75  76-95  96-99
10096.76
Tried the taper command. But the angels are different. Not the way...
EDITED: 10 Feb 2021 by MALA
10096.77 In reply to 10096.75
Frenchy: Please...the loft option in the extrusion - which one have you choosen?
10096.78 In reply to 10096.76
Hi Mala, with the tapered method the angles will be the same with respect to the cut plane. If you need them consistent to some other measurement maybe you will need to construct the angled surface how you need it first and then intersect pieces with that.
10096.79 In reply to 10096.76
Visual!
The angles are the same. in the opposite sides and directions. Because the chamfer is on the opposite sides and direction.
If the cuts were "Mirrors", the angles would match, as the user is wanting.
10096.80 In reply to 10096.79
Here is an example using a fillet...
There is nothing different about that fillet. It is a RADIUS all the way around both sides. The "same" radius.
Where the pinch points are and where the open spots are, depends on the angle of the surfaces to each other...
If you want them to "Match" at the same "OPPOSITE" side, the angles have to be the same, "OPPOSITE"...
10096.81
Burman, thanks for your thoughts. I cannot proof it without the 3d file. But I guess a signifikant mistake in your construction is the angle of the cutting. Did you use the cutting cube in one of my previous files? I guess no. Yours has an perpendicular cut. But thats not the right angle...cheers, Mala
10096.82 In reply to 10096.81
Hi Lara,
is the attached what you need.
Barry
Updated Zip.
This gives constant slope length.
EDITED: 16 Jan 2021 by BARRY-H
10096.83 In reply to 10096.82
YES
10096.84 In reply to 10096.83
Hi Lara,
I have updated the file as I had trimmed the inner and outer diameters and this was not correct.
You only need to trim the outer diameter thus giving a constant slope length.
Barry
10096.85 In reply to 10096.81
Hi Lara,
""""""Did you use the cutting cube in one of my previous files? I guess no. Yours has an perpendicular cut. But thats not the right angle...""""""
No. My post was not a solution. I was responding to the post where you asked "why" this was the case and you noted that the opposite sides matched.
I created an illustration to show "why" and how you can't do it with a fillet/chamfer or "winkle"....
Sounds like Barry is bringing an understanding and solution...
10096.86 In reply to 10096.82
That's great Barry, you cracked the code!
So it's making the second cut by intersection with a tube instead of a second planar cut.
Sorry if i make an Iso Curve on these slopes (ring2 by Barry) i don't obtain same length ? ...(idem for the second one 1.29...)
10096.88 In reply to 10096.84
There are two 3dm files of interest.
1. Lara's RingCutter.3dm
2. Barry's Ring2 solution. Import this on top of 3dm #1.
To see what is going on, Remove the 4 tops and 4 bottoms of Lara's(Mala's) cutting boxes. Also remove tops and bottoms of Barry's cutting boxes.
The 13mm tube is cut by the 26er cutting planes. (Curve is sort of ellipsoid?)
Barry has swept a 1.3unit radius circle centered on the inner tube cut. It is Rot (RED). (There are 4 red tori_ellip.)
The 15mm tube is trimmed ..... by these red tori_ellip. This cut is DIFFERENT that the cut of the 28er cutter.
The only need for the 28er cutter is to get the initial radius of the red torus_ellip.
(Edit/correction...Barry did do the cut of the 15mm tube with the 28er cutter, as an earlier step.)
Edit see Barry's next post, gif.
So the width of the bevel (winkle) is 1.3 units. Well, 1.3000001 units anyway.
........Loft........ the larger and smaller ellipsoid, and a tiny bit more geometry to join the 13mm sections to the trimmed 15mm sections, and the "cones".
The 13mm tube and the 15mm tube remain as large tori, with circular "right angle" cross sections.
Very cool Barry.
EDITED: 17 Jan 2021 by BEMFARMER
Size: 168.2 KB, Downloaded: 20 times, Dimensions: 711x514px
10096.89
this is the method I used.(see gif below)
Pilou your correct the iso's are slightly different +/- 0.02 mm but this maybe a display issue.
Barry
Edit: Added loft instruction.
EDITED: 17 Jan 2021 by BARRY-H
Size: 842.9 KB, Downloaded: 47 times, Dimensions: 800x533px
Perhaps Barry's small circle sweep could be made to the larger toric_ellip, instead.
-Brian
10096.91 In reply to 10096.90
Yes that’s also an option depends on what goes on the 13mm diameters in the finished article.
It’s also possible to start with the 13mm diameter pieces produced with the cutters sweep a given
Slope and length around the ends then use the new edges to sweep the main circle thus creating the larger diameter.
I did an experiment this way but the larger circle is not concentric to the 13mm and not necessarily a perfect circle.
Barry
10096.92
Need to model a further, much simpler version of the ring. I got problems filleting the Ring at the 4 curves at reduced part of the ring. No tricks, just rotated circles and a sweep...
10096.93
...I made a workaround with 2 lofts and two sweeps. I only want to understand why the filleting failed at sweptAtOnce version...
Filetting is only possible on hard edges.
When your edges are soft, it's impossible.
Michael explained it in the 34th post of this forum subjects.
Have fun
10096.95 In reply to 10096.94
It is a sweep with only circles. Do not know why the generated geometry has soft edges.
Show messages:  1-15  16-35  36-55  56-75  76-95  96-99
