Modelling a Böbbel
 1-20  21-40  41-60  …  81-99
10096.1
I must model a little higher point on a ring.
I trimmed the ring (with michaels help) with trimming tool. Before trimming I was able to lift the points and modify the surface.
But after trimming with two neighboured rings in order to avoid the whole ring changing I cannot pick the circles points.
I tried the diverse options for sweeping and for trimming...no success.
Do you got an idea where my mistake is?
Kind regards, Mala
EDITED: 10 Feb 2021 by MALA
10096.2 In reply to 10096.1
Hi Mala, are you trying to do that ? In that case, i have first select the 4 half circle and join them. Then the 4 lines to make the rails and join them. Then, sweep the 3 profil curves with the 2 rails. Then boolean diff the donut with two curves and delete the part you don't want.
Size: 143 KB, Downloaded: 77 times, Dimensions: 800x468px
Other method
Copy Move parts wanted to change
Separate
Hidden Function: ShrinkTrimmedSrf (Press Tab and write ShrinkTrimmedSrf )
Add pointsif necessary and move them as you want...
PS You can make the same directly on the ring! (so don't need to Move)
-just separate Up Down faces !
Here the separate move
Here directly on the ring!
Select All Separate
Select the 4 little parts
Show Points
ShrinkTrimmedSrf
etc
EDITED: 3 Jan 2021 by PILOU
10096.4 In reply to 10096.3
Thank you both...
More natural for me is french pilous way...
I want do it directly on the ring.
What does it mean: "Select all separate - select 4 little parts"
And..."Show Points" does not work for the other parts in my model. Neither the ring nor the two trimmed splines. Only at circle spline I made the sweep with.
Mala
10096.5 In reply to 10096.4
Load your File
Select All the ring then Separate! ;)
Cick on the empty Space for Deselect
Select the 4 curvated Surfaces(by clicking one by one) wanted to deform
At the end of this 4 selection "Show Points"
You must have all ring "Show Pointed" + 4 Surfaces "Pointed" enlighted
Press Tab & Write SchrinkTrimmedSrf
You must have only 4 surfaces Pointed!
If you have not enough Points just Add Points as you want (always on these 4 surfaces)
Have fun modeling!
PS
If you want all ring as "Show pointed" don't make the 4 Surfaces Selection and the SchrinkTrimmedSrf
then click a big Surface then move points etc...the 4 Surfaces must be separated again for moving points shown!
EDITED: 4 Jan 2021 by PILOU
10096.6 In reply to 10096.5
...hey...French...thanks a lot...but I guess I´m too silly for that operations! Hmmm´....
Mala
10096.7 In reply to 10096.6
Why do you not select all points along the common "Line" ?
Like that you take points from each surface sides points on the same time! ;)
I am in the case of all points rings visible but that will be exactly the same in your case of 4 Surfaces! ;)
I hide the curve limit for more easy move & selection...
10096.8 In reply to 10096.1
Hi Mala, how about this method:
Select your "bump profile" curve:
Use Construct > Extrude with "Cap ends" checkbox turned off to make this:
Next step is to delete or hide the curve used to extrude since it will interfere with selecting the edges there.
Then next select these edges:
And run Construct > Blend to make a blend surface like this:
Now delete the extrusion and mirror the blend surface and use Edit > Join to glue the pieces together:
Is that close to what you are trying to get?
10096.9 In reply to 10096.1
Hi Mala, or also what about a sweep using 3 profile curves all in the one sweep like this:
It isn't necessary to cut it, the way profile curves transform between each other means the bump shape will not have an effect on this region of the sweep:
You have also Loft...
Copy move sections for more easy process... Join the 2 circular sections if they are half... Then Loft the 3 sections
Order of selection of the sections is very important!
Caps or not caps is possible, loose, straight style can be also asked depending of wanted resultat!
And of course at the end if you ask Show Points for the "middle section"
you will have Real Time deformation! ;)
Any selection of Points can be moved in any directions!
10096.11 In reply to 10096.10
...I´m almost sure: people like me costs you helpers time of your live! B U T : Now I got the principles for that modeling. They are so simple that it not may be true. Sorry for my moi-skills, deeply. Where are you..in order to send tons of chocolate to you. (ok - better salad and vegetables...?!)
What I´m now working on is the finetuning of my splines....
How can I make it better and smooth? Is it handcraft and feeling-modelling? Or are there given rules to make the form fine? Or automatic refining tools in moi?
Last tips and impulses would be welcome...
Best regards, Mala
10096.12 In reply to 10096.11
<<<Or are there given rules to make the form fine?
Just a Moment of Inspiration is sufficient! :)
How cool is it, it is not ? ;)
Your object is yet sufficient for some Flow fantasy!
10096.14 In reply to 10096.11
Hi Lara,
I am sure that questions are welcome. The answers generated help many others.
Esthetics might favor tangent or G1 or G2 curvatures?
10096.15 In reply to 10096.11
Hi Mala,
Hi Mala yes it will be a matter of adjusting the control points of the curves you used for constructing the shape. There aren't any tools currently for doing that automatically.
Localized bumpy details can be awkward to model with a CAD modeling toolset, the main focus in CAD surfacing is on making broadly smooth sheets and not really on fine local bumpy details.
Bumpy shapes and fine tuning bumps can be done better in a displacement brush based modeling system like 3D Coat or ZBrush. Those allow you to refine bumpy details using brush strokes directly on the surface.
Moi3D is not done to create bumped surfaces, but you have a possibility to do it with Moi3D with its plugins.
Here is a exemple of antic coin pendant and a memento mori coin.
I did a grayscale of the bump and use the plugin heightmap to create this in Moi3D.
The printed result is pretty good...
10096.17 In reply to 10096.13
Smart, Frenchy, new inspirations in deed.
Little more light onto the small "nupsies"....
thanks, Mala
10096.18 In reply to 10096.16
Thanks Phiro. Bump is not in focus at the moment, best regards... Mala
10096.19
One more modeling thing: breaking the surface along line.
The car images are showing what I need to do...breaking the surface.
How do I do that? I tried some boolean operation to make a cut in the ring. Then my intention was it so lift the surface... But I failed. Which tool should I use?
Regards, Mala
10096.20 In reply to 10096.19
a cool method by Chipp Walters! ;)
Show messages:  1-20  21-40  41-60  61-80  81-99
