Ui scaling porblem?
All  1-5  6-11
10095.6 In reply to 10095.4
Hi Chris, Chipp's gui editor is for v3 and isn't set up for v4. So if you're using that you're also getting a v3 moi.css file with the wrong kind of flexbox attributes in it.
But if you have one colorized how you want if you post it here or send it to me I can tune it up to have the v4 flexbox attributes.
10095.7 In reply to 10095.6
Ok, would I be able to modifiy that later per hand? Is that even straight forward? :D
10095.8 In reply to 10095.7
Hi Chris:
Kind of... The best was is to use a diff utility comparing your moi.css with the default installed one for v4.
Then you can see the places where they are different. Keep the properties that are setting color values, but update any flex-box proertie.
10095.9 In reply to 10095.7
Hi Chris, try the attached verson.
10095.10 In reply to 10095.9
thx alot!
Maybe a qol improvment for future stuff is to build such an editor inside moi ;)
10095.11 In reply to 10095.10
Hi Chris, yes I'll probably be giving that a try sometime during the v5 dev cycle.
Show messages: All  1-5  6-11
