Ui scaling porblem?
All  1  2-11
10095.2 In reply to 10095.1
Hi Chris, that looks like the kind of thing that can happen if you have installed a customized moi.css file made from moi v3's moi.css file.
If you restore the original v4 moi.css file those should go away most likely.
If you have some customizations to moi.css that you want to have in v4 if you can post your moi.css I can probably tune it up to have the new flex-box properties that the V4 UI is set up to use. V3 used an older and now deprecated webkit specific flex-box for layout. The V4 UI is structured to use the newer standard flex-box properties and if you yank those away and only have the old webkit flex-box properties set up in moi.css you will have the kind of layout problems you are experiencing.
10095.3 In reply to 10095.2
The only thing that is custom in my .css is the color you see in the surrounding sidepanel and I never had a v3 css modified ...mhm
Edit: and resetting that .css didnt changed the issue
10095.4
After installing the v4 release it went back to normal....maybe it was a borked .css
Is the chippwalter gui changer maybe not up to date and could have damaged something?
10095.5 In reply to 10095.3
Hi Chris, can you please upload your v4 installation's moi.css file either here or e-mail it to me at moi@moi3d.com ?
10095.6 In reply to 10095.4
Hi Chris, Chipp's gui editor is for v3 and isn't set up for v4. So if you're using that you're also getting a v3 moi.css file with the wrong kind of flexbox attributes in it.
But if you have one colorized how you want if you post it here or send it to me I can tune it up to have the v4 flexbox attributes.
10095.7 In reply to 10095.6
Ok, would I be able to modifiy that later per hand? Is that even straight forward? :D
10095.8 In reply to 10095.7
Hi Chris:
Kind of... The best was is to use a diff utility comparing your moi.css with the default installed one for v4.
Then you can see the places where they are different. Keep the properties that are setting color values, but update any flex-box proertie.
10095.9 In reply to 10095.7
Hi Chris, try the attached verson.
10095.10 In reply to 10095.9
thx alot!
Maybe a qol improvment for future stuff is to build such an editor inside moi ;)
10095.11 In reply to 10095.10
Hi Chris, yes I'll probably be giving that a try sometime during the v5 dev cycle.
Show messages: All  1  2-11
