UV mapping
All  1-7  8-17
10094.8 In reply to 10094.7
Hi Tony,
> In practice, as I understand, you have to insert a geometry drawn in MOI and exported to Obj
> for example and he creates a flat square image where you then create the texture with a
> photo editing program? .... or does it work differently?
Yes that's basically it - the UV mapping generates a 2d coordinate value for every polygon vertex to control how a 2D texture image will be applied onto the polygons.
The tricky part is avoiding the image getting stretched out or compressed in different areas.
For chunks of dirt like you want it may be better to sculpt those in using 3D Coat or ZBrush though.
10094.9 In reply to 10094.8
Thanks Michael,
the thing that is not clear to me is, for example in the case of 3D coat, it is applied on the rendering or it is a separate thing .... in the sense the 3d must be done directly in 3d coat or it can be done in moi, rendered in artlantis and finished in 3D coat? .... this is not clear to me.
10094.10 In reply to 10094.9
Hi Tony,
In 3D coat, you will paint over the UV map, this map can then be exported with your 3D model, and rendered in any 3D renderer.
If you want to paint, one of the best tool for this is Substance Painter : https://www.substance3d.com/products/substance-painter/
You need 1st to generate your UV map, in a 3D software, then you export this map to Substance painter with your 3D model, and do your paint there.
10094.11 In reply to 10094.10
yes I only know that it doesn't integrate with my render engine ... I think
10094.12 In reply to 10094.11
I suppose you make a little mistake of post writer! ;)
10094.13 In reply to 10094.12
Hello Virtual_Francky
I think I understand but my rendering program does not generate UV maps and I need a program that generates UV maps, Michael has listed some programs that can generate them but the demos do not allow the export of the map (you cannot save) so I couldn't test the program and the resulting map .... so I couldn't create anything.
Now I simply used a dirt map to simulate the dirty bodywork but it is not the same as a 3d painter in my opinion .... the effect is much more unreal than a dedicated map
EDITED: 4 Jan 2021 by TONY77
10094.14 In reply to 10094.13
You answer to Virtual_Francky (FRANCK_BIROLINI) not to me! ;)
10094.15 In reply to 10094.14
Sorry Pilou I got the wrong name ;)
10094.16 In reply to 10094.15
No problem :)
about easy easy Paint or texture on 3D volumes take a look to the Paint 3D given (so free) by Windows (if you have this OS)
Not headaches and not long learning curves! :)
You can insert any volumes made by Moi ;) OBJ, STL, FBX...
EDITED: 4 Jan 2021 by PILOU
10094.17 In reply to 10094.16
Thank's Pilou :)
Show messages: All  1-7  8-17
