MOI3D v 4.0 decimal separator
All  1  2-4
10093.2 In reply to 10093.1
Hi pr1, if you are using the comma as the decimal separator MoI will be expecting you to have a space between the coordinate values.
So for example when drawing a line to place a point at x = 5,2    y = 10,3 you should put in:
5,2 10,3
10093.3 In reply to 10093.1
hi.
you could also use space as the coordinate separator
http://moi3d.com/4.0/docs/moi_command_reference1.htm#__XYZ%20/%20Distance%20/%20Angle
1,2 4,5
best,
marco
10093.4
Hi Michael and Marco,
Thanks for your feedback.
Apparently, both periods and commas work as decimal separators, as long as you use spaces as coordinate separators:
5.2 3.4
or
5,2 3,4
That's cool.
Cheers,
pr1
Show messages: All  1  2-4
