Is it possible to select one of the faces of an object and then scale it?
 1-8  9-28  29-32
10091.29 In reply to 10091.27
oh wooow :-), let me study this move I'll get back to you :-)
10091.30 In reply to 10091.29
I have forgotten to say that places where you click on the surfaces are very important !
Else you will not obtain the result wished!
The 8 possible places are indicated in this link!
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
Else it's a very funny method for deform something out of the classical methods or when anything works! ;)
10091.31 In reply to 10091.28
Hi Psygorn,
> Is it possible to make a command or button that helps you to achieve what I mentioned? for
> example imagine you select a face of a cube u run that command then it separates the face,
> give you the ability to scale it and then makes it joined to other edges using loft order and
> gives you one single piece?
Well it could be possible but it would only work for special cases as well.
For example this object:
Would generate this result:
So that could be pretty weird.
It's better to construct your scaled object from the start.
10091.32 In reply to 10091.31
oh that's right!
Show messages:  1-8  9-28  29-32
