Network Hell
All  1-2  3-6
10089.3 In reply to 10089.1
Another thing to be aware of is that it can be difficult with domed structures using Network to not have evidence of the curve layout influencing the surface shape in a visible way especially with "poles".
One thing that can help is to include a circle curve as one cross section approaching towards the pole like this example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3550.6
Some other things that can be good for a smooth dome is to do the dome as a sub-d model and use the new Sub-d converter in MoI v4 to bring it over.
Another way to get a very smooth dome like shape is to start with a surface of revolution like a sphere or a custom one that you make with revolve and then turn on surface control points and deform those points rather than doing a curve driven construction for that particular type of shape.
10089.4 In reply to 10089.3
Michael!!! Smooth moves my dude - that tip about putting the pole at the top did the trick! I also added a small circle there to smooth out any further wrinkled.
Thank you for your help! :)
10089.5
...This was the result in the end. Many thanks for you help!
Size: 1.2 MB, Downloaded: 102 times, Dimensions: 2160x2160px
10089.6 In reply to 10089.5
Hi Super9 wow that turned out great!
Show messages: All  1-2  3-6
