Is it possible to check curvature type between surfaces?
All  1-4  5-14
10086.5 In reply to 10086.4
Thanks. For curvature graph I use Rhino. I`m looking for fast way to check continuity between surfaces. What is not possible at Rhino 6. In Rhino 7 its possible only one pair at time. Old Autodesk VSR plugin allowed to check multiple edges between surfaces at one time but it works only with Rhino 5. VSR plugins was killed before v6. For now if I will update from Rhino 6 to Rhino 7 it will be mainly for this command: EdgeContinuity https://docs.mcneel.com/rhino/7/help/en-us/commands/edgecontinuity.htm . I hoped that I will find solution like that in MoI or as external paid script or so. This EdgeContinuity command is also very limited because of checking only one pair at time. It would be nice what continuity type is present on each edge of a whole object.
10086.6
Check this rhino's plugin.
"Global Edge Continuity" analysis tool for quickly analysing surface continuity between multiple surfaces at once.
I found this recently on youtube, this guy (Andrew Jackson) mainly uses solidworks but uses rhino for analysis.
https://www.youtube.com/watch?v=4FceX93m7T8&t=23s
10086.7 In reply to 10086.6
Hi Ko, sorry no there currently isn't a tool in Moi for doing that. I would recommend using Rhino for that analysis.
10086.8 In reply to 10086.6
10086.9
Also FreeCAD have a tool for Zebra map shading, under Workbench Curve. is free opensource tool multi-platform.
Y-zebra-checkt
Corner-zebra-checkt
Greetings
Else... ;)
You have also the free Polycad who has Zebra and other stuffs! :)
Moi <---> PolyCad with IGES
https://www.polycad.co.uk
EDITED: 14 Oct 2022 by PILOU
10086.12 In reply to 10086.11
PolyCAD don't support trimmed surfaces!
10086.13 In reply to 10086.12
'Zebra Stripe': {
lightingStyle : 'CustomLevels',
specularHighlights : true,
specularBrightness : 100.0,
specularFocusSize : 0.0,
metallicLighting : true,
fixedLightPositions : false,
customKeyLightLevel : 0.6,
customFillLightLevel : -0.5
Zebra striping and others only give a visual indicator of continuity. No information about the type of curvature that exists…
Just a note.
Show messages: All  1-4  5-14
