Select flat, face selection to edge
All  1-7  8-12
10085.8 In reply to 10085.1
Hi rolnxyz,
> 1. Is there a way / script to convert a face selection to its corresponding curve line outline?
It looks like you found this one already? There is another version here too:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5922.37
> 2. Is there a way to select all continuous faces in of object within an angle threshold? Many
> polymodeling programs have this, like cinema4d phong break selection, or RizomUV wand selection,
> or blender select linked faces. I'm trying to quickly select faces without having to click too much.
Right but MoI is not a poly modeling program and isn't designed to work on faceted model geometry like you have here. You're much better off doing this type of poly modeling in a program that's designed to do that type of work like cinema4d, blender, etc... like you mention.
For the Window selection method, drag the window in a view where you're looking straight down on the face, that will make it easier to capture them all in one window:
It should be possible though to make a script that will grow selection to adjacent faces that are coplanar. I'll see about cooking one up for that.
10085.9 In reply to 10085.1
Hi rolnxyz, here are some scripts that might help.
First one - grow face selection to one neighboring face that is coplanar with the current face selection:
script: /* Grow face selection to neighboring coplanar faces */ var faces = moi.geometryDatabase.getSelectedObjects().getFaces(); for ( var i = 0; i < faces.length; ++i ) { var f = faces.item(i); var edges = f.getEdges(); for ( var j = 0; j < edges.length; ++j ) { var e = edges.item(j); var faces2 = e.getFacesOfEdge(); for ( var k = 0; k < faces2.length; ++k ) { var f2 = faces2.item(k); if ( f2.id != f.id && f2.isPlanar && f.isPlanar && f.isOnPlane( f2.planarFrame ) ) f2.selected = true; } } }
Second one - grow face selection to all neighboring faces that are coplanar with the current face selection:
script: /* Grow face selection to multiple neighboring coplanar faces */ while ( true ) { var did_one = false; var faces = moi.geometryDatabase.getSelectedObjects().getFaces(); for ( var i = 0; i < faces.length; ++i ) { var f = faces.item(i); var edges = f.getEdges(); for ( var j = 0; j < edges.length; ++j ) { var e = edges.item(j); var faces2 = e.getFacesOfEdge(); for ( var k = 0; k < faces2.length; ++k ) { var f2 = faces2.item(k); if ( f2.id != f.id && f2.isPlanar && f.isPlanar && f.isOnPlane( f2.planarFrame ) ) if ( !f2.selected ) { f2.selected = true; did_one = true; } } } } if ( !did_one ) break; }
10085.10 In reply to 10085.9
That's awesome Michael, thanks for the scripts!
10085.11 In reply to 10085.9
thx you for these !!
BY Max SMirnov
Increase selection
script: function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',1);}} var so = moi.geometryDatabase.getSelectedObjects(), sf=so.getFaces(), i; for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges()); es(so.getEdges());
Decrease sélection
script: function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',0);}} var gd = moi.geometryDatabase; gd.invertSelection(); var so = gd.getSelectedObjects(), sf=so.getFaces(), i; gd.invertSelection(); for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges());
Show messages: All  1-7  8-12
