shovel connection
All  1-7  8-15
10084.8 In reply to 10084.7
Yes but can be open in "V", in "U" etc around the handle! ;)
10084.9 In reply to 10084.8
The very bottom of the handle socket "cylinder" is Vee notched. And there is a bottom seam.
Crude .3dm of usage of the physical contour guage on a pretend real shovel curve.
Only one pretend cross section curve is shown (in RED).
I must have 40 or so shovels...
Some idea...you can adapt your surface to any form...
10084.11 In reply to 10084.10
Thanks Brian and Pilou :)
10084.12 In reply to 10084.1
Hi Tony, you could put in some profile curves and do trim and blend. Maybe something like this:
10084.13 In reply to 10084.12
Thanks Michael for your always helpful advice
10084.14 In reply to 10084.13
Hi Tony,
Here's a version:
I can find some errors still, that i would change but it's just an example...
Like when I fillet the join, the fillet runs all the way up the connection, which removes my "wrap" of the steel. If you saw just before that where i cut the shovel base back to meet that part, I think if I did that later, the fillet wouldn't run up like that...
Anyway, just a different look.
10084.15 In reply to 10084.14
Thanks Burrman :)
Show messages: All  1-7  8-15
