I believe that the steel begins flat, and is bent/stamped. The upper part of the steel wraps around the handle, as a "cylinder", open at the bottom.
I can find some errors still, that i would change but it's just an example...
Like when I fillet the join, the fillet runs all the way up the connection, which removes my "wrap" of the steel. If you saw just before that where i cut the shovel base back to meet that part, I think if I did that later, the fillet wouldn't run up like that...
