V4 released!
 1  …  22-41  42-61  62-81  82-101  102-121  …  182-188
10083.62
Congratulations Michael on the V4 release!
EDITED: 17 Jan 2021 by SBEECH
10083.63
Hi, Michael.
In the Moi Wiki, the hotkeys section, it says:
1) On a scene browser color swatch, Ctrl+Shift+Left click will assign the selection to that style without altering the visibility or locked state of the objects to match the current style.
2) Clicking on the name part of a scene browser item is used for selection, if you hold down Ctrl while clicking on it it will work for deselection instead of selection,
and if you hold down Shift while clicking on it it will only select currently visible objects instead of selecting and showing all objects that belong to that slot.
Does not work. Or do I not understand something?
Beta version from December 21, 2020.
10083.64 In reply to 10083.63
Hi WN, those are out of date, they applied to MoI version 2. The scene browser in MoI v2 did not have a selection dot indicator on the right-hand side of the scene browser item. Instead you could click the text to select or deselect. When the selection dot was added in v3 then selecting by clicking on the text was removed.
Also in version 2 if you clicked on a swatch where all the current objects assigned there were hidden, it would hide the objects. This behavior wasn't too good though and so that was changed in v3 as well to not alter the visibility state of objects when assigning to a style.
I'll update the wiki to remove those obsolete hotkeys.
10083.65 In reply to 10083.64
Now everything is clear, thank you!
10083.66 In reply to 10083.65
Hi
Does the old v3 scripts work also on v4?
Perttu
10083.67 In reply to 10083.66
Hi Perttu,
Yes most of them do. A small number needed minor updates because the newer script engine in v4 will throw an error on invalid script code that was silently ignored in the old v3 version.
10083.68 In reply to 10083.67
just one silly question ..
Can I still keep the version 3 on my computer
and use both if needed
Perttu
10083.69 In reply to 10083.68
@ Pertu
Of course yes ! :)
...but it's very more powerful to launch many sessions of V4 in the same time!!!
(depending of your Hard memory available! ;)
10083.70 In reply to 10083.68
Hi Perttu, yes MoI v3 and v4 can co-exist on the same machine.
You don't need to uninstall v3 when you get v4.
10083.71
Hi, Michael.
The fillet tool does not work with this geometry.
Will there ever be a fix or always use a workaround?
Size: 138.6 KB, Downloaded: 142 times, Dimensions: 1708x973px
Message 10083.72 deleted 25 Jan 2021 by MKDM
10083.73 In reply to 10083.1
Hello Michael!
Life's too short...too many topics on this forum :)
Could you help me?
I bought the V4 some days ago but I'm in trouble with many scripts that worked for V3.
Is there a place (inside this forum) where I can easily get all the necessary infos to get V3 scripts easily working also with V4?
I hope so.
Try with an Arc Circle tangent without unity but not sure you can go to the end! :)
(then make a trim not shown here)
or with the function itself...but you must enter some very small number! :)
0.0000001
and i am not sure of what and where you want fillet something!
EDITED: 25 Jan 2021 by PILOU
10083.75 In reply to 10083.73
Hi Marco,
> Could you help me?
> I hope so.
Yes, this is the place right here. Just list which specific scripts you are having problems with and I will reply here with some information to help you.
Thanks, - Michael
10083.76 In reply to 10083.71
Hi WN,
> Hi, Michael.
Actually no there will never be a fix that covers every single type of possible geometric shape because geometry comes in infinite varieties so it isn't possible to test every kind of shape. That's one of the things that makes this a difficult area for software.
But usually there are not a lot of problems in curve filleting compared to solids filleting.
In this case here it's related to the specific "anti-tangent" shape you've made.
For this particular bug a quick workaround is to use Edit > Separate and then select 2 separate curves at a time and do Fillet, followed by Edit > Join. That will avoid the bug in the corner processing for this case which I've added to my list to investigate fixing.
Also make sure that the script is the latest version.
I recollect that a few scripts were tweaked to be compatible during the early v4 beta periods...
10083.78 In reply to 10083.76
Hi, Michael.
I asked about the corrections only for this case. Because I know that this is a pain for both you and us.
I follow this topic on the forum and try not to ask you tormenting and repetitive questions, but apparently I did not succeed.
Thank you for the proposed solution to the issue, as always, everything is surprisingly simple.
10083.79 In reply to 10083.75
Ok Michael.
Thanks a lot!
Well...I've a bunch of scripts...but because right now I can't have enough spare time to devote to this task, I'm going to pospone my request.
Anyway, thanks for the help.
In the next weeks I hope I will start picking some V3 script to be fixed with your help.
See you next time :)
10083.80
Hi, Michael.
Look at the file, it has a Loft for two figures.
I used a rectangle star and a Loft.
Size: 117.8 KB, Downloaded: 131 times, Dimensions: 1600x1200px
10083.81 In reply to 10083.80
Hi WN, it seems that there is a slightly different result with one surface malformed depending on the ordering of the profile selection.
In the one on the left if you click on the rectangle first and then click on the star and then do the loft, it generates an ok result. If you click on the star first and then the rectangle second then there is one piece that isn't formed properly.
But in general a loft between curves with a different number of segments with sharp corners will not make a very good result, it's usually better to loft between smaller pieces to control which curve segments will match together. Or split pieces up so that the curves you are lofting between have the same number of segments so they can be matched segment to segment.
So in your case, maybe a reasonable approach would be to set up connections like this:
Then split the rectangle up, and join the pieces together. Then with t here being the same number of segments in each curve they will match segment-to-segment giving this result:
Show messages:  1  2-21  22-41  42-61  62-81  82-101  102-121  122-141  …  182-188
