V4 released!
 1-5  …  126-145  146-165  166-185  186-188
10083.166 In reply to 10083.165
Hi Michael
I apologize for not being able to express what I really need.
I attach 2 files that are:
"Script.txt" where the scripts that each icon in the attached image "Styles.jpg" and its corresponding code are indicated (it is written as it would be added as a keyboard shortcut).
"SidePane1.htm" is the current file of the pop-up window of the image "Styles.jpg", where the 3 icons of the file "Script.txt" are already added
I hope this time you understand what I want to do.
And the file "SidePane1.htm" that I need you to modify, I suppose it will help me to know how to add possible useful scripts for me.
And I thank you again for your invaluable help.
EDITED: 22 Sep 2024 by BOOLEANO
10083.167 In reply to 10083.166
Hi Booleano, so for the icons you need to make each icon image into its own separate file. Usually the icons are 64 width 64 height PNG image files.
Then copy your 3 new icon image files into the "icons" sub-folder inside the ui folder. Then you'll be able to use them in a command button.
For running those scripts, step #1 is to modify your SidePane1.htm file to add a <head> section, usually <style> and <script> go in the <head> section of an html file.
So that would look like this:
<html>
	<head>
		<style>
			/* Turn off text block under command button icon */
			moi\:CommandButton > div {
				display:none;
			/* Cambio de tamaño de los iconos */
			moi\:CommandButton > img, moi\:CommandMenuButton > img, moi\:CommandSplitButton > img {
			width:8em;
			height:8em;
		</style>
	</head>
	<body class="SidePaneBody">
Now add a <script> section inside the <head> after the <style>:
<html>
	<head>
		<style>
				display:none;
			width:8em;
			height:8em;
		</style>
		<script>
		</script>
	</head>
Then inside the <script></script> section you can add functions that contain script code:
		<script>
			function ScriptCodeFunction1()
		</script>
copy the script code from your Scripts.txt inside the function, in between { }.
To make a command button call the script function, put in an onclick="" attribute in the moi:CommandButton element, like this:
<moi:CommandButton icon="icons/icon_filename.png" onclick="ScriptCodeFunction1()">Text here</moi:CommandButton>
You can remove the command="" attribute from these particular 3 buttons, they will be calling script code inside this same file instead of running a command.
Let me know if you're still stuck.
10083.168 In reply to 10083.167
Hi Michael.
Understood everything perfectly.
My pop-up window is only going to have little-used scripts, it is very overwhelming to remember 20-40 keyboard shortcuts, at least for me, that's why I needed this.
So once again thank you very much.
You can tell me where I can check the syntax of the version in which the MOI scripts are written.
For many years now, I was programming in C ++, Borland's version for MS-DOS (Windoss did not yet exist), and it would be useful for me to at least know how to modify some script, without going crazy.
If I need to add more sripts they will all be in a red box, to know that they are not tools.
10083.169 In reply to 10083.168
Hi Booleano,
There isn't really a place currently where that can be checked other than by running it in MoI.
In the future i would like to work on a built in script editor that would help make it easier to write and debug scripts. It wiill take a lot of effort to make it though.
10083.170 In reply to 10083.169
Hi Michael.
I really think that I would only need the necessary Java version, and I would search the Internet for the information I need.
I will never write a script, only on occasion would I modify an existing one.
Thanks.
10083.171 In reply to 10083.170
Hi Booleano, the script language version that MoI uses is called JavaScript and the specific version name is called ECMAScript v5 .
10083.172 In reply to 10083.171
Hi Michael.
Thank you
10083.173
Don't understand what gives here:
MindSet
10083.174 In reply to 10083.173
As you can edit Dimension Text anything can be writed!
or can be also an perspective effect!
etc...
10083.175 In reply to 10083.174
So, it really doesn't offer measurements as fractions?
Hmm, maybe that makes sense; thought I was doing something wrong... both examples are coplanar.
Thanks!
10083.176 In reply to 10083.173
Hi Mindset,
Dimension values are rounded using the setting under Formatting > "Decimal display" for decimals and Formatting > "Fractional display" for feet & inches.
So if you want to display a fraction less than that you'll need to set the display precision to be tighter. You can set the default used for new dims under Options > Dimensions, and you can set the properties for existing ones by selecting it and pushing "Details...".
If you're still having a problem can you please post the .3dm model file with your dim in it so I can take a look.
10083.177 In reply to 10083.1
im loving it!!!! performance is great and so stable!
Ok, I finally got back to tuning up the web site a little more and there is now a "what's new" page for V4 here:
http://moi3d.com/4.0/whatsnew.htm
10083.179 In reply to 10083.178
Super!
10083.180
Hello Michael, everyone, I'd like to ask whether there are incremental updates to V4 since its initial non-beta release. The reason why I'm asking is because I upgraded to V4 pretty early on and I was wondering if there have been any minor version updates released since which I may be missing.
Thank you!
10083.181 In reply to 10083.180
Hi Larry, no there haven't been any upgrades to v4 as of yet. I am hoping to start v5 betas soon, sorry it's taking a while to get that started.
10083.182 In reply to 10083.181
Hello Michael!
Happy New Year to you and yours and everyone and everyone's here!
As far as I'm concerned, please take your time. You did exceptional work with both V3 and V4. I especially love V4! I only asked about minor version increments since I like to stay up to date with my software. V5 will be done when it's done.
Have an awesome 2022!
- Larry.
10083.183 In reply to 10083.182
Thanks Larry, Happy New Year!
10083.184
Hi there,
I can't get "Ext.Scripts" button to appear in my moi v4 GUI, I get it in the MOI v3 (but it's 32 bit so can't use it for bigger objects anymore) but whatever i do copy/paste scripts/ui stuff from v3 i to v4 i still can't get the button show up in moi v4 :(.
Can someone point me to example how to do that in moi v4 ?
Lewis
www.ram-studio.hr
Skype - lewis3d
10083.185 In reply to 10083.184
Hi Lewis, the CustomUI mod from Max is different for v4. There is a new version of it for v4 and it is installed differently, in v4 it goes in the MoI appdata startup folder.
You can get it at https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1 , use the link for the v4 one not the one for v3.
Show messages:  1-5  …  106-125  126-145  146-165  166-185  186-188
