Q: Assign Series of Object Snaps into Hotkeys.
All  1  2-3
10081.2 In reply to 10081.1
Hi Elang, yes this is possible by putting in some script as the "Command" part of the shortcut key under Options > Shortcuts.
These are controlled by the moi.drawingAids object, which has these properties on it that can be set to true (checked) or false:
objectSnapOrigin
objectSnapAxis
objectSnapEnd
objectSnapMid
objectSnapCen
objectSnapInt
objectSnapQuad
objectSnapPt
objectSnapOn
objectSnapOnSrf
objectSnapPerp
objectSnapTan
objectSnapPerpPerp
objectSnapTanTan
> - Ctrl + Alt + 1 : Checks (enable) Object Snap for Origin, Axis, and Points, and DISABLE any others.
This one would go like this:
script: var da = moi.drawingAids; da.objectSnapOrigin = da.objectSnapAxis = da.objectSnapPt = true; da.objectSnapEnd = da.objectSnapMid = da.objectSnapCen = da.objectSnapInt = da.objectSnapQuad = da.objectSnapOn = da.objectSnapOnSrf = da.objectSnapPerp = da.objectSnapTan = da.objectSnapPerpPerp = da.objectSnapTanTan = false;
> - Ctrl + Alt + 2 : Checks (enable) Object Snap for End, Mid, Intersection, and DISABLE any others.
script: var da = moi.drawingAids; da.objectSnapEnd = da.objectSnapMid = da.objectSnapInt = true; da.objectSnapOrigin = da.objectSnapAxis = da.objectSnapCen = da.objectSnapQuad = da.objectSnapPt = da.objectSnapOn = da.objectSnapOnSrf = da.objectSnapPerp = da.objectSnapTan = da.objectSnapPerpPerp = da.objectSnapTanTan = false;
> - Ctrl + Alt + 3 : Checks (enable) All of Object Snap.
script: var da = moi.drawingAids; da.objectSnapOrigin = da.objectSnapAxis = da.objectSnapEnd = da.objectSnapMid = da.objectSnapCen = da.objectSnapInt = da.objectSnapQuad = da.objectSnapPt = da.objectSnapOn = da.objectSnapOnSrf = da.objectSnapPerp = da.objectSnapTan = da.objectSnapPerpPerp = da.objectSnapTanTan = true;
For MoI v5 I've made a note to add something to set all or clear all with one script function call to make this kind of script to be shorter.
Hope this helps! - Michael
10081.3 In reply to 10081.2
Thank you so very much, Michael.
You're breath taking! :)
Show messages: All  1  2-3
