Fabric seat
 1-5  6-25  26-30
@Tony
On your last picture, I think you have 2 surfaces, green and white.
The white is useless.
I apply the "blendcap" script (http://moi3d.com/forum/index.php?webtag=MOI&msg=7370.6) with the internal edge of lofted surface.
Don't remember this cool "Blend Cap"!
Just need a "wall" else don't success!
EDITED: 21 Dec 2020 by PILOU
10073.28 In reply to 10073.27
@Phiro
Thanks, I had guessed that it was a script ..... initially I thought it was a Blend applied to a simple surface .... that's why I didn't understand.
Thanks again ;)
10073.29 In reply to 10073.25
@Phiro
Can you confirm that this is the effect of the blendcap? ... or did I miss some steps?
Size: 156.4 KB, Downloaded: 41 times, Dimensions: 1266x890px
@Tony,
I think that this effect is due to lofting.
I use the option to have a "loose" loft and my two orange curves are coplanar so the blendcap is only a plan.
Warning...
There is a small warning with the blendcap script.
This script "cut" the edge to do its surface, so after doing blendcap, your original edge is cutted.
Show messages:  1-5  6-25  26-30
