Fabric seat
 1-20  21-30
10073.21 In reply to 10073.20
Yes, of course .... it was clear even before ..... obviously I'm the one who's wrong.
The only doubt is in the passage of the revolve rail evidently I create a wrong curve because to me the "cushion" comes out like this.
Size: 121.7 KB, Downloaded: 21 times, Dimensions: 1105x908px
Yes, before revolving, you have to rebuild your curves to avoid the multiples edges if your original curves were with hard points.
So I read that these are called "wrinkles".
For vinyl, they steam them, to reduce them.
The number of points in the iso-curves has an effect on the DistortCurves script?
Rebuild can add points. Higher tolerance, more points?
10073.24 In reply to 10073.21
Ok everything clear .... only the last step is not clear to me .... from the loft onwards .... forgive me but I'm translating using an online translator and the last step is not clear
I got up to here:
Size: 155.7 KB, Downloaded: 36 times, Dimensions: 1167x964px
10073.25 In reply to 10073.24
Cool result Phiro
For an ultima perfect result the "boundaring tube" should be also a little perturbated! ;)
@Tony
I believe that you must maybe have the same number of "Points" when you "Rebuild" your curve(s)
Like this even each curve is tortured crease will be more aligned and less disparated than in your case!
PS The distort curves thread by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6659.13
Else Blend method from a Subdivided box
For make a Blend each edges selected must be belong to a surface!
(so some tricky process :)!
EDITED: 21 Dec 2020 by PILOU
@Tony
On your last picture, I think you have 2 surfaces, green and white.
The white is useless.
I apply the "blendcap" script (http://moi3d.com/forum/index.php?webtag=MOI&msg=7370.6) with the internal edge of lofted surface.
Don't remember this cool "Blend Cap"!
Just need a "wall" else don't success!
10073.28 In reply to 10073.27
@Phiro
Thanks, I had guessed that it was a script ..... initially I thought it was a Blend applied to a simple surface .... that's why I didn't understand.
Thanks again ;)
10073.29 In reply to 10073.25
@Phiro
Can you confirm that this is the effect of the blendcap? ... or did I miss some steps?
Size: 156.4 KB, Downloaded: 41 times, Dimensions: 1266x890px
@Tony,
I think that this effect is due to lofting.
I use the option to have a "loose" loft and my two orange curves are coplanar so the blendcap is only a plan.
Warning...
There is a small warning with the blendcap script.
This script "cut" the edge to do its surface, so after doing blendcap, your original edge is cutted.
Show messages:  1-20  21-30
