Hello pilou, thank you for your feed back.
I use to work with millimeters .... my dimensions lines are correct in mm ... Sorry, don't understand what you mean it isn 1000 times too big ? Maybe i'm too tired ...
Indeed I can now frame the plan in the .pdf but I find that the procedure is do-it-yourself ... On the other hand, I still don't see the dimension lines visible on my .pdf file?
In definitve, I was working with the September v4 beta version which had a lot of problems with the export of files ... everything is ok now with the new V4 version .... I finally understood why I didn't understand what was proposed by pilou !
I'm happy the beta stage is going to finish now ..... :)
There was some pdf problem, some sort of "truncation", for a v4 beta, back a version, or two. So definitely use the most recent beta!!!!! There are some posts, back a month or 2, or so.
Bonjour Pierre, yes the PDF export was the last major area of work for v4 and these were some of the main things that were fixed up with it for the Oct-27 v4 beta release.
The v4 final release is coming up very soon, there are a few bug fixes since the Oct-27 beta so I will post a new v4 beta that should match the v4 final release.
One of the problems was that it was centering on the upper-right corner of the page instead of the center of the page, and also dimensions didn't export. Both should be fixed in the current Oct-27 v4 beta release.
Hi Michael. I was doing a small shop drawing for my father with the new dims (which are awesome!). When I select the dims and linework and export to a pdf file, I am not getting the dims on the output?
Please check what version of MoI you are running. Dims export to PDF was one of the last features added and was implemented in the Oct-27-2020 v4 beta, if you're running a version older than that then that would be the problem.
You can get the last v4 beta at https://moi3d.com/beta.htm and also the v4 final version is out now as well.
If that wasn't the problem can you please post or e-mail (moi@moi3d.com) the .3dm model file with your dims in it that won't export?
