Align to surface.
All  1-5  6-10
10070.6 In reply to 10070.4
> 1/22/2020, face.dropPoint(pt), yields 2D uv of surface point, closest to input pt.
> So pt just has to be close to surface, or could be a point on an isoline.
The point given to face.dropPoint() can actually be anywhere, it will find the closest point on the surface from the input point.
> I figure that a point (say the center point of a circle), could be acted on by a force, either
> attractive or repulsive, move to pt2, and a new point on surface found, with new circle
> aligned to new surface normal. What is the time overhead?
Well it depends a lot on the complexity of the surface and also the complexity of the trimming boundaries. It does have to do quite a bit of work but you could probably do a few hundred calls.
10070.7 In reply to 10070.5
Hi Barry, please try the attached plugin command.
10070.8 In reply to 10070.6
Thank you Michael. The surface would have to be locally flat-ish, relative to the radius of the circle. Circle centerpoints that are 2D far away would have to be 3d far away, (no nearby folding). D3- force has the force equations, but only does boundaries for 2d constant x or 2d constant y. Or huge 2d arc boundaries, with external centers. The only way to repel from a surface curve boundary, AFAIK, would be to replace boundary curve with lots of fixed points, close together relative to circle radius...which drives up overhead.. Or many small arcs with external centers.. And boundary curves need to be "reasonable". Surfaces with internal boundaries, (e.g. holes) similarly. Have not located efficient boundary curve repulsion algorithm.
Re surfaces, points on curve (e.g. isocurve), on surface, can be used to get normals, for alignment to surface.
Brian
10070.9 In reply to 10070.8
Maybe dropPoint could be used on boundary curves to advantage?
10070.10 In reply to 10070.7
thank you that works fine.
Have a good Xmas.
Barry
Show messages: All  1-5  6-10
