(Paramatric) Icosahedron in MOI ?
All  1-6  7-16
10069.7 In reply to 10069.1
Hi Tom,
Re: Terminology.
Icosahedra (plural), are solids with twenty planar faces. There are an infinite number.
The regular icosahedron has equilateral triangular faces.
Polyhedra have various numbers of faces.
In the past, I have used MoI to manually build the platonic solids, as an exercise.
There was a file with a lot of "gem" solids...
Also, antiprism script.
EDITED: 18 Dec 2020 by BEMFARMER
10069.8 In reply to 10069.7
"The regular icosahedron has equilateral triangular faces!
This one is the one I need !
10069.9 In reply to 10069.8
Do not have one at work, but see here for .3dm file:
http://www.rhino3d.nl/pythposter/pyth3dm-eng.html
You can always construct one in MoI. http://moi3d.com/forum/index.php?webtag=MOI&msg=2140.46
Before I knew of MoI: MoI Forum 2008 ref link:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2140.55
There is a zip file of gif and names further down.
10069.10 In reply to 10069.8
Tom
If all you need is a regular icosahedron, it is available as a pulldown option in Solids/Polyhedron node.
Other options include: Tetrahedron, Octahedron, Hexahedron (Cube) & Dodecahedron
EDITED: 18 Dec 2020 by JFH
10069.11 In reply to 10069.10
That is a great tip, James.
I am attaching what I do in Cinema 4D and importing the result as *.obj in MOI.
And what I would obviously do in MOI, if I would know, how to :-)
In Cinema I can subdivide a basic icosahedron as shown. And there is great
cloner tool from which I diplayed its basic properties
10069.12 In reply to 10069.11
Maybe Copy to Point after Selected Target...
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
Look also Dispersion by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
10069.13 In reply to 10069.12
Hi Pilou.
I tried out copytopoint and had not found time yet to look at diepersion
what I will do today !
10069.14 In reply to 10069.12
Thanks Pilou.
Regarding dispersion by Max:
The recently added methods for dropping points on surfaces, and getting surface normals, etc.,
should open up some more possibilities.
10069.15 In reply to 10069.11
Tom,
OK so now I understand what you meant earlier:
quote:
I am just in need of a number of ICOSAHEDRA with a different
number of facets.
In NodeEditor, you can subdivide icosahedron (2 subdivides shown) and attach cylinders to vertices:
The .nod file is attached....however you will need current NE mod nodes, found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
Hope this helps
10069.16 In reply to 10069.15
Hi James, you are amazing ! I really have respect for those
who have mastered the art of advanced nodology. The more
I dig into the Icosahedron the more I am fascinated by its
geometrical properties ...
Show messages: All  1-6  7-16
