Metal stand problem
 1-4  5-24  25-33
10067.25 In reply to 10067.24
Thank you so much Michael :)
10067.26 In reply to 10067.21
Or I guess if the Top profile curve was longer it could go like this. You have to build an extruded surface for the cutting object instead of just using the curve because you don't want to cut all the way through:
Then Chamfer:
10067.27 In reply to 10067.25
3DM file for the last one above.
10067.28 In reply to 10067.24
I hope I succeeded .... what do you think? .... obviously the two sides now I have joined them in one piece .... in what I am attaching they are divided and then joined .... now I have made a single piece as suggested by Michael and Pilou
Size: 88.6 KB, Downloaded: 45 times, Dimensions: 1249x958px
10067.29 In reply to 10067.28
Looks pretty good to me!
10067.30 In reply to 10067.28
This last method of yours is also very nice .... thanks again Michael :)
10067.31 In reply to 10067.30
You're welcome Tony! So kind of the key strategic things is to establish the full extended shape as the base for this kind of thing.
Else another method for bend something...the Flow function very polyvalent !
Can be make some deformation but...
10067.33 In reply to 10067.32
Thank you Pilou for the support
Show messages:  1-4  5-24  25-33
