Metal stand problem
 1-20  21-33
10067.21 In reply to 10067.20
I understand Michael :)
<< how do you cut the model at the height of the round part?
You can always cut anything by a simple curve, a surface, a volume...
By Trim if you don't want keep the object closed, by a boolean Diff if you want keep the object closed!
10067.23 In reply to 10067.20
Perfect you progress to the final !
For the Boolean Diff or Union between 2 objects (or more) don't hesitate to have "true intersections" and not a simple "contact surface"!
EDITED: 18 Dec 2020 by PILOU
10067.24 In reply to 10067.21
Hi Tony, I've attached a version using the method of putting in a blend curve to make a smooth path and then forming a cutting surface.
Once you put in the blend curve, then the curves are not all on the surfaces anymore and they are not planar either so they can't cut by projection well either.
But by forming an extended parting surface then the parting surface can be intersected. So in the attached versions the parting surfaces are these pieces, see how they extend out a little ways so they can cut the main body surfaces, this is a method that you can use when the shape bends around in such a manner that there is not a single 2D view that can be used to form all the cutting profiles.
So instead of 2D profiles you use a 3D surface as the cutting object. You can use 2D profiles and project them to form most of the curves to work with though.
10067.25 In reply to 10067.24
Thank you so much Michael :)
10067.26 In reply to 10067.21
Or I guess if the Top profile curve was longer it could go like this. You have to build an extruded surface for the cutting object instead of just using the curve because you don't want to cut all the way through:
Then Chamfer:
10067.27 In reply to 10067.25
3DM file for the last one above.
10067.28 In reply to 10067.24
I hope I succeeded .... what do you think? .... obviously the two sides now I have joined them in one piece .... in what I am attaching they are divided and then joined .... now I have made a single piece as suggested by Michael and Pilou
Size: 88.6 KB, Downloaded: 45 times, Dimensions: 1249x958px
10067.29 In reply to 10067.28
Looks pretty good to me!
10067.30 In reply to 10067.28
This last method of yours is also very nice .... thanks again Michael :)
10067.31 In reply to 10067.30
You're welcome Tony! So kind of the key strategic things is to establish the full extended shape as the base for this kind of thing.
Else another method for bend something...the Flow function very polyvalent !
Can be make some deformation but...
10067.33 In reply to 10067.32
Thank you Pilou for the support
Show messages:  1-20  21-33
