The Grey area: -B- Class surfacing in Moi
All  1-7  8-11
10064.8
Brian:
that map should work in all render engines
here more examples about artifacts in subd
Ed:
You were the first to do a car using Max subd ;)
Max script convert directly inside Moi
Moi subd need to export and re-import...it's up to Michael :)
Pilou:
You win the car ! but i'm curious:how you guess...maybe with the help of a vintage cars amateur ?..or you are one of them?
i think to finish in January,then i'll send you but it will be an heavy file
This is an Alfa and finish results will go on my old thread:The Alfaholics
http://moi3d.com/forum/index.php?webtag=MOI&msg=6512.1
Next week i'll be out of home but i'll return here about subd
Merry Xmas !
M
10064.9 In reply to 10064.8
@Mauro
No I am not but... :) I have thought first to a Thunderbird but as you are Italian...
That was easy to put voiture coupée italienne in the google reseach engine by image!
As i have remarked the middle sharp bonnet ...it was a game's boy to find by a little scrolling! :)
PS
I's a pity that i don't remember your thread about Alpha because she was inside! :)
EDITED: 17 Dec 2020 by PILOU
10064.10
Exploring of SubD importer goes on :)
After mirroring half surface i make new "polys" on the central part of the hood
Transition on the intake area inspire me to make a "triangle poly" like in picture below
Moi SubD Importert will convert also 3 side "polys" (Max SubD converter not allow this) check pictures at the end
Now let's do an experiment:create the wheel slot generating a "N side" surface
extrude edges
trim the extrusion with a straight line,select all edges and do a planar surface
Moi importer can convert this type of "N sided" surface (Max SubD converter not allow this)
I didn't follow this in my final car,It's just to show what the converter can do
I discovered an option that allow to choose:less patches-more patches
Sadly i discovered it too late when i finished the car.You can have less seams with a more uniform distribution on the surface
That's crucial when you'll do booleans and fillets to get doors,windows,door handle slots etc.
Here red arrows show slightly different seam construction between left-right sides,but it's a mirrored surface
...pushing more: let's see if it's possible to get a thickened surface
Surface
thickener in action
thickened surface= SOLID !...not bad in this difficult situation :)
Here inside the fender
...pushing some more:try a fillet on a complex edge loop door window
let me say: our f----d filleter works ! :)
Very promising :)
10064.11 In reply to 10064.10
Cool tricks!
Show messages: All  1-7  8-11
