Exploring of SubD importer goes on :)
After mirroring half surface i make new "polys" on the central part of the hood
Transition on the intake area inspire me to make a "triangle poly" like in picture below
Moi SubD Importert will convert also 3 side "polys" (Max SubD converter not allow this) check pictures at the end
Now let's do an experiment:create the wheel slot generating a "N side" surface
extrude edges
trim the extrusion with a straight line,select all edges and do a planar surface
Moi importer can convert this type of "N sided" surface (Max SubD converter not allow this)
I didn't follow this in my final car,It's just to show what the converter can do
I discovered an option that allow to choose:less patches-more patches
Sadly i discovered it too late when i finished the car.You can have less seams with a more uniform distribution on the surface
That's crucial when you'll do booleans and fillets to get doors,windows,door handle slots etc.
Here red arrows show slightly different seam construction between left-right sides,but it's a mirrored surface
...pushing more: let's see if it's possible to get a thickened surface
Surface
thickener in action
thickened surface= SOLID !...not bad in this difficult situation :)
Here inside the fender
...pushing some more:try a fillet on a complex edge loop door window
let me say: our f----d filleter works ! :)
Very promising :)
