construct and transform menus both open
All  1-7  8-12
Message 10063.8 deleted 18 Dec 2020 by WIMVERBE
10063.9
would it be possible to add scale 2D and 1D too? How do I do that then?
don't know the difference between commandset and command, and where to get the correct syntax for the 2 extra icons and commands.
Tnx
wim
10063.10 In reply to 10063.9
Hi Wim, a "commandset" is a group of commands, it's a button like this that pops out a sub-menu of related commands:
Then these are command buttons that run an individual command when you click on them:
Well where do you want them to go? There isn't currently any empty space next to the "Scale" command set button.
10063.11
I would place them instead of the twist icon and the "tube" icon which is missing here, 2 things I don't use so often. But am I wrong when I assume that if I would just insert 2 extra lines in the script, the window would simply increase in width with 2 extra columns? I don't see any window formatting in the script, so I presume that the frame adapts to the amount of items in a row/column, no?
10063.12 In reply to 10063.11
Hi Wim, sorry I thought you were talking about placing them somewhere in the regular side pane UI, I didn't know you meant on that dialog box.
Give the updated one a little further down in that thread a try:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9758.3
There is formatting in there - it's set up in a table and every section in between is a table row and then a
is a table cell. So to replace Twist and Tube, those are on line number and 76 in the file, they look like this:
	        <td><moi:CommandButton icon="moi://ui/icons/TwistIcon.png" command="Twist"></moi:CommandButton></td>
                <td><moi:CommandButton icon="moi://ui/icons/PipeIcon.png" command="Pipe"></moi:CommandButton></td>
You can find the regular scale command buttons inside the file Scalings.htm inside MoI's ui sub-folder. Look in there to see what you should put for icon="" and command="" for scale command buttons. - Michael
Show messages: All  1-7  8-12
