How to edit text in an efficient way
All  1-6  7-20
10061.7 In reply to 10061.5
Hi Chris, also to set the default properties for things like dimension font sizes, that is done under Options > Dimension.
10061.8 In reply to 10061.6
yeah I know :) Sry for not clarifying more. Since its burried in details and you answered with a shortcut script before I was hoping for the same ;)
If not possible maybe a QoL thing for v4 patches or v5 :)
10061.9 In reply to 10061.8
Hi Chris, it is possible but what's the case where it is going to help out? The text property is something that I can understand could be set separately for each different object.
But it isn't very likely that the font properties would be set differently for each object, that's something that tends to be set the same for a whole group of objects.
If you could maybe show the kind of model or project where it would help then I might understand what you need better.
If you are finding that you need to frequently edit the font properties into a few different categories then there is a property preset mechanism that would do that job better. For that you go to Options > Dimensions and create a separate preset for each "style" of dimension that you want to create. Then when you draw a new dimension there is an option inside the dim command to tell it which preset to use.
That way you can assign an entire predefined set of properties or "style" to the newly drawn dim right from the beginning and you don't need to edit any if its properties individually after that.
10061.10 In reply to 10061.9
Thx that makes total sense indeed :)
10061.11 In reply to 10061.10
hi
here a example of layout ( in french )
perhaps it can help someone to make professional layout directly in M.O.I.
Chri
EDITED: 9 Jan 2021 by CHRI
Size: 181 KB, Downloaded: 77 times, Dimensions: 1199x910px
10061.12 In reply to 10061.11
Excellent!
Not ISO norm ? ;)
10061.13
hi
here a example of layout in english
Chri
Size: 172.4 KB, Downloaded: 43 times, Dimensions: 1030x814px
10061.14
hI
the next release of this layout will simplify scalling
Chri
10061.15 In reply to 10061.14
hi
here 2 files in differents size
and the explanation to change easily the text size by layer
Hope this could help
Chri
Size: 218.1 KB, Downloaded: 57 times, Dimensions: 1650x859px
10061.16 In reply to 10061.15
Thanks Chri, I think that probably another way that could be set up to change these things will be by some extension of the annotation property preset mechanism. Something like have annotations remember the property preset that they were created with and then have an option that when the preset is modified it will reapply it onto those annotations.
Also some things like select annotations of a particular preset.
Currently the annotations are designed for relatively light duty like marking up a simple model for a shop drawing. It's not really intended to be a full replacement for a 2D CAD program for doing detailed drawings, not yet anyway. I will be adding to it over time though.
EDITED: 28 Dec 2020 by MICHAEL GIBSON
10061.17 In reply to 10061.16
hi Michael
Thanks for you quick answers
I understand what you mean
In this project, documents are one shot .
When you have prepared the documents, there is only few things to change each time. Quick Text Dialog script is enough
Unlike you, I think that MOI is a perfect software for making technical drawings.
if i'd like for example, import 2D files for the parametric part, it's easy to use free software like SOLVESPACE witch is also incredible.
your software is magnificent ( and very efficient )
Chri
EDITED: 28 Dec 2020 by CHRI
10061.18 In reply to 10061.17
Thanks Chri, I'm glad that you like it! :) It is definitely missing some things for detailed 2D drawings such as line styles and hatching.
It is convenient for quick simple dimensions though!
10061.19 In reply to 10061.18
Hi
line styles ... in the next wish list for V5
Have a good day
Message 10061.20 deleted 4 Jan 2021 by MICHAEL GIBSON
Show messages: All  1-6  7-20
