Exploded view in more directions
All  1  2-9
10060.2 In reply to 10060.1
Do you mean Top Bottom - Left Right ... Front Back ?
If Yes just click On them on the bottom page ! ;)
10060.3 In reply to 10060.2
Hello PILOU,
can you show me example please ??
Yes in all deirections at once
10060.4 In reply to 10060.3
Sorry maybe i don't understand your problem...
Split for see all views...
EDIT correction: (Native MoI) ExplodeMove. Shows up in CustomUI, or use "Tab" (see Pilou post next.)
Old answer from 2013: http://moi3d.com/forum/index.php?webtag=MOI&msg=6061.4
I am confused re: Is a cube viewed from 6 external points of view, or is the cube separated, and the 6 faces moved apart in 6 directions?
Or is it some drafting view, of 5 faces arranged 2D, in a PDF, like isometric...?
EDITED: 14 Dec 2020 by BEMFARMER
Else you have a native ExplodeMove (hiden function)
Press TAB and write ExplodeMove then Press Enter or Right CLick
(you can also write explodemove or EXplodemove ...etc but without space) !
or make a ShortCut as usual with ExplodeMove in the second column
10060.7 In reply to 10060.6
Thank's Pilou. I corrected my previous post.
Wondering if Michael's ExplodeMove factory could be enhanced, for any useful purpose?
10060.8 In reply to 10060.1
Hi doehlma,
> Do anybody know if it´s possible to create exploded view in more defined
> directions ? (one direction script I found)
Sorry it's not quite clear what you mean by exploded view, can you say what the one-direction script you found was? That would then help clarify what you are asking about.
Was it possibly the Make2D command that you found? If so then try this script that generates a 2D drawing from 4 views:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
10060.9 In reply to 10060.6
This is the function I found..
I have to try it again .. because in my first test I not saw this effect in all axes..
Thanks all for support and hints
Great community I have to say
Now I tested it again .. and what I have to say .. It is great running :-)
Show messages: All  1  2-9
