Thanks Ed. I just received the 3d printer few weeks ago and this is my first project where I model myself the parts and then I assemble them ( for the first tests and try I just downloaded STL from the net). You just opened me a new door :) I will give them a try for sure!!
If I can ask in your opinion PLA is fine for those kind of projects where there are involved PCB and circuits ?
I use PLA 90% of the time. It does absorb water, so use it for indoor projects only. No issues with electronics indoors. After trying several brands, I settled on www.proto-pasta.com
For outdoor projects, use PETG filament. PETG is used to make water bottles.
I had some issues with the corners of the lid warping during the print. I now model a 4 layer high, 2" diameter disk at each corner to help hold the object to the bed. Makes the model look like it has Mickey Mouse ears. The ears get cut off after the print is finished and cooled down.
Looking forward to see what else you end up making.
WOOW Ed, it looks fantastic, pretty advanced project. Really like it, for the moment I stick around raspberry pi and similar devices, I wish one day I will be able to go more wild an play with serious circuits like you do!
