Equidistant array on surface / automatic Pave
 1-5  6-25  26-45  46-65  66-75
10052.46
came across this method and gave it a try.
http://v5.rhino3d.com/m/discussion?id=6377196%3ATopic%3A99631
Equi distanced objects on surface
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=6602.2
Moi3d method of getting offset curve on surface
Created grid lines on surface using above methods and then
array along curves by distance and align to surface.
Barry
10052.47 In reply to 10052.45
Hi, very good to talk to a jewellery designer.
Your question : My task is to create a design concept / rendering which should be realistic enough
to be manufactured as presented in the concept.
As the pave technique has been around a while I am asking myself which method was used to
distribute the gems regularly in the pre-digital era - it is quite challenge !
Regarding the picture posted I would be interested to know more about the technique used as
it differs from the common prongs - do you have any idea ?
The current auto-pave tools within Rhino seem to be very powerful though my question is if
they just fill up the surface randomly or if it is possible to line the gems up in individual
pattern as well.
I am still uncertain which is the best way to solve the challenge within MOI - what would
be your approach ?
10052.48 In reply to 10052.44
Thanks Brian, I did not get entirely which would be your approach ?!
10052.49 In reply to 10052.46
Hi Barry, this looks very promising ! Thank you - I will have a look into
your links right now !
Maybe Scatter by Max Smirnov can make something for you ? ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
10052.51 In reply to 10052.46
Barry, two questions :
>>Created grid lines on surface<<
You used Curve> Isocurve I guess
Which comman did you use to offset this extracted Is
>>array along curves by distance and align to surface.<<
"align to surface!> do you mean the ArrayGem script ?
10052.52 In reply to 10052.50
Hi Pilou, good you remembered me, I had downloaded it but did nor have a look yet !
10052.53 In reply to 10052.47
Hi Tom,
My reason for asking related to a problem specific to rendered images with grain set stones like pave.
Matrix had a script which not only layout the stones & beads (aka grains or claws) relevant to the surface but also a "bearing cutter" that was used to boolean out the area to create a "seat" for the stones pavilion.
For "real world" use, this boolean cutter wasn't really required, only a positioning dimple/marker (traditionally a drilled hole) which a skilled Setter would open up with burrs to seat each individual stone & cut up the grains (claws) to hold them.
Those using Matrix for creating realistic renders of designs with pave diamonds found they DIDN'T quite look realistic.
This was caused by the boolean bearing cutter working fine for a "real world" STL model but not for its rendering.
Unlike "real world", the render model needed the bearing cutter to be larger than the stone so the rendered metal didn't interact with how the diamond material worked.
This situation was happening when using V-Ray but think it was also happening for those using Keyshot too.
So bottom line, you had to create two different models, one for render use only & one for STL "real world" use...and don't ever mix them up!!
I did a few models featuring "stone work" but never bothered trying to do a complete pave layout within MoI.
Good Luck
HTH, Colin
10052.54 In reply to 10052.51
Hi Tom,
I did not use iso curves.
I projected a datum line onto the surface and used the vertical edge as the other datum.
Taking dimensions shown on photo I swept circles and used the pipe produced to cut surface.
The cut edge is used to sweep and cut the next edge and so on.
These cut edges are converted to curves by copying to clipboard and pasting back to become the grid.
You can boolean union the cut surface or take a copy before cutting.
I produced grid lines in the 'Y' as a check but this was not needed in this case as array along curve by
distance seemed ok.
Barry
Edit: Forgot your 2 question.
No its not the ArrayGem option.
It's the array along curve which as a align to surface button and an option to space by distance.
EDITED: 14 Dec 2020 by BARRY-H
10052.55
This is the image. Anyone who may know more about the kind
of stone-setting / prongs / construction used in this objects -
any information is appreciated !
10052.56 In reply to 10052.48
Hi Tom,
Colin's advice is excellent.
Barry's technique is elegant, and the way to do the layout, absent the exotic pave physics,
IMHO.
I was focused on creating a flat surface, for flow method. Your gem surface is not developable, but the horizontal and vertical lines indicate that (near) planar tiling methods or layouts can make good patterns. Tiling theory permits a finite number of uniform layouts of polygons. Hex tiling is among these. (= circle packing). Cell distortions for your surface should be limited, and can be compensated for by the artist. Patches on the frog have separation zones.
Using a spare surface, strips/ curves (edges), can be done by MoI array of a bunch of lines, and trim. MoI often has alternative ways to accomplish a task.
The iso-curves of your surface are "angulated", absent remeshing?
ps came across a Java, open source, academic, biology, use of (charting force).
10052.57 In reply to 10052.56
not sure if it's of any interest but Freecad as a surface/mesh unwrap tool.
It's in the mesh designer workbench (samples attached of surface taken from Tom's model).
Meshmixer as a unwrap option as well.
I don't think flow is an option in this case though.
Barry
Edit:
Split surface prior to flattening file added.
10052.58 In reply to 10052.57
Thank you Barry.
I'll have a look later.
Another possibility, if it works or not, HexaGrid On Surface, from food for Rhino (uses Grasshopper). Circa 2012, so may have issues???
I think all the methods have geometry limitations to compensate for...Cell distortion, fixed gem size...
10052.59 In reply to 10052.54
Hi Barry - very thankful for your explanations, that helped a lot !
What do you think about the option tu use "intersectCurve" to generate
the curves instead of cut. copy an paste ?
Did you array the whole group of gem+prongs or each of the elements
individually ?
10052.60 In reply to 10052.59
Hi Tom,
Yes the intersect curve could be used but the tube does not always cut thro both sides.
I arrayed the gem & posts every other grid curve & just the gem in the middle.
The method using the tube cutters maintains the rigid dimensions the gem & post make.
So if there is a large curvature on the surface the centre dimensions are maintained.
See photo.
Hope this helps.
Barry
10052.61 In reply to 10052.55
Hi Tom,
That piece shows how proper pave is done with hand cut grains.
The whole idea of "pave" is that it should look like a "paving of stones".
The metal "spaces" (islands) that are left between each stone then get "cut up" to form the grains (claws)
Each of those grains gets pushed over the seated stone & is "beaded" (rounded & burnished) down onto the stones "crown" (angled top edges)
This technique is not something that every Jeweller can do, most will shop this work out to a highly skilled Setter who specialises in it.
In a "real world" situation, the metal piece would typically be handed over to the Setter along with a bag of stones & HE would do the layout & markings to drill, then open up each hole to fit each individual stone.
Here's a few YouTube videos that'll give you a better insight of what happens & how it's done.
https://youtu.be/_h-VQavSPWM
https://youtu.be/cqaIAlSIagQ
The CAD versions of this technique being created within Rhino/ RhinoGold/Matrix/MatrixGold is just a poor man's copy.
You can emulate the basic look of pave in CAD but it never looks truly like the "real article".
HTH, Colin
EDITED: 14 Dec 2020 by COLIN
10052.62 In reply to 10052.61
Thanks Colin - those Setters do have incredible skills ! Unbelievable what they achieve at such
microscopic scale !
I agree, the CAD pave looks pretty "industrial" and lifeless compared to the handmade ones.
A realistic rendered fake look could maybe be achieved by using sculpting tools. Any images
with closeups of such handmade grains you may know of, just post them here please.
10052.63 In reply to 10052.56
Hi Brian, I agree, fantastic advice !
I am pretty impressed by those automated pave tools, but I also like to cook up my own
soup - with the kind help of amazingly skilled MOIers ;-)
""MoI often has alternative ways to accomplish a task.""
MOI has its own very individual and ingenious philosophy which could not be better expressed
as in its name : "Moments Of Inspiration" It is exactly its reduction to a handy array of essential tools
which makes the magic work - its more an artists workshop than an industrial hall jam packed with
an infinite number of hightech tools. Thats why I love to work with it as it matches my own philosophy
in so many aspects.
""The iso-curves of your surface are "angulated", absent remeshing?""
Sorry, I dont get what you mean.
10052.64 In reply to 10052.54
Barry, btw, is the Dimension tool you used in the screenshot one of MOIs scripts ?
10052.65 In reply to 10052.64
Hi Tom,
The dimension tool is in the latest V4 beta.
Barry
Show messages:  1-5  6-25  26-45  46-65  66-75
