Equidistant array on surface / automatic Pave
 1-14  15-34  35-54  55-74  75
10052.35 In reply to 10052.34
Added note...
"""""Flow distorts the objects""""
Well, only by a difference in the base and target surfaces...
That is where the work is. To get a base surface that maps well to the target surface.
I think mike or chipp did a tute on this part
10052.36
Cuty luxuous!
10052.38 In reply to 10052.33
Brian, thank you for your ideas !
10052.39 In reply to 10052.34
Hi Burrman. I added an example surface with a 2mm gem.
10052.40 In reply to 10052.35
"""""Flow distorts the objects / Well, only by a difference in the base and target surfaces...
That is where the work is. To get a base surface that maps well to the target surface.""""
Thats a hint, I need to take a deeper look !
10052.41 In reply to 10052.36
>> https://vimeo.com/118113245?width=800&height=480<<
Have not seen this one - good find !
10052.42 In reply to 10052.41
The frog's back is close to being a developable surface, a portion of a cylinder.
10052.43 In reply to 10052.39
Aaaaannnnndddddddd.......
Couldn't do it... sorry.
10052.44 In reply to 10052.43
The surface chops up into strips. There is still some double curvature.
Wish I knew how to run Rhino unroll or smash.
Rhino demo, free and functional for 90 days, installed today. It took over my .3dm data type...
No clue how to run Rhino.
I did a little unwrapping in MoI of the curves copied from the strip edges, but am quiting now.
I'll delete this file in a day or two.
EDITED: 12 Dec 2020 by BEMFARMER
10052.45 In reply to 10052.32
Hi Tom,
I can tell you from personal experiance there was at least four Jewellers using MoI back in the very early days (V1)
Some of those like myself have continued with MoI but in my own case, I'm no longer using it for jewellery.
Most moved back to Rhino because R4 already had a lot of the dedicated jewellery based Plug-in's.
The "leader" of those jewellery Plug-in's was Matrix which had superior Pave scripts & used a custom version of V-Ray for rendering.
My question for you is are you creating a "real-world" CAD model or just a render with your resultant pave model?
HTH, Colin
10052.46
came across this method and gave it a try.
http://v5.rhino3d.com/m/discussion?id=6377196%3ATopic%3A99631
Equi distanced objects on surface
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=6602.2
Moi3d method of getting offset curve on surface
Created grid lines on surface using above methods and then
array along curves by distance and align to surface.
Barry
10052.47 In reply to 10052.45
Hi, very good to talk to a jewellery designer.
Your question : My task is to create a design concept / rendering which should be realistic enough
to be manufactured as presented in the concept.
As the pave technique has been around a while I am asking myself which method was used to
distribute the gems regularly in the pre-digital era - it is quite challenge !
Regarding the picture posted I would be interested to know more about the technique used as
it differs from the common prongs - do you have any idea ?
The current auto-pave tools within Rhino seem to be very powerful though my question is if
they just fill up the surface randomly or if it is possible to line the gems up in individual
pattern as well.
I am still uncertain which is the best way to solve the challenge within MOI - what would
be your approach ?
10052.48 In reply to 10052.44
Thanks Brian, I did not get entirely which would be your approach ?!
10052.49 In reply to 10052.46
Hi Barry, this looks very promising ! Thank you - I will have a look into
your links right now !
Maybe Scatter by Max Smirnov can make something for you ? ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
10052.51 In reply to 10052.46
Barry, two questions :
>>Created grid lines on surface<<
You used Curve> Isocurve I guess
Which comman did you use to offset this extracted Is
>>array along curves by distance and align to surface.<<
"align to surface!> do you mean the ArrayGem script ?
10052.52 In reply to 10052.50
Hi Pilou, good you remembered me, I had downloaded it but did nor have a look yet !
10052.53 In reply to 10052.47
Hi Tom,
My reason for asking related to a problem specific to rendered images with grain set stones like pave.
Matrix had a script which not only layout the stones & beads (aka grains or claws) relevant to the surface but also a "bearing cutter" that was used to boolean out the area to create a "seat" for the stones pavilion.
For "real world" use, this boolean cutter wasn't really required, only a positioning dimple/marker (traditionally a drilled hole) which a skilled Setter would open up with burrs to seat each individual stone & cut up the grains (claws) to hold them.
Those using Matrix for creating realistic renders of designs with pave diamonds found they DIDN'T quite look realistic.
This was caused by the boolean bearing cutter working fine for a "real world" STL model but not for its rendering.
Unlike "real world", the render model needed the bearing cutter to be larger than the stone so the rendered metal didn't interact with how the diamond material worked.
This situation was happening when using V-Ray but think it was also happening for those using Keyshot too.
So bottom line, you had to create two different models, one for render use only & one for STL "real world" use...and don't ever mix them up!!
I did a few models featuring "stone work" but never bothered trying to do a complete pave layout within MoI.
Good Luck
HTH, Colin
10052.54 In reply to 10052.51
Hi Tom,
I did not use iso curves.
I projected a datum line onto the surface and used the vertical edge as the other datum.
Taking dimensions shown on photo I swept circles and used the pipe produced to cut surface.
The cut edge is used to sweep and cut the next edge and so on.
These cut edges are converted to curves by copying to clipboard and pasting back to become the grid.
You can boolean union the cut surface or take a copy before cutting.
I produced grid lines in the 'Y' as a check but this was not needed in this case as array along curve by
distance seemed ok.
Barry
Edit: Forgot your 2 question.
No its not the ArrayGem option.
It's the array along curve which as a align to surface button and an option to space by distance.
EDITED: 14 Dec 2020 by BARRY-H
Show messages:  1-14  15-34  35-54  55-74  75
