Equidistant array on surface / automatic Pave
 1-13  14-33  34-53  54-73  74-75
10052.14 In reply to 10052.6
Hi Tom,
> I not to happy about needing Rhino plus Rhinogold for just one project
> so I am still thinking about a way managing it within MOI.
Probably the MoI method would be to manually place them using Transform > Orient.
As noted some months ago:
The Oct.10, 2019 V4Beta Wiki, under resources, shows new scripting properties for Face objects, including face.evaluateNormal( uv ).
Also Jan. 22, 2020 V4Beta Wiki, has scripting properties: face.dropPoint( pt ), brep.dropPoint( pt ), and Updated face.planarFrame().
But at the moment I have too many projects :-)
Flow hex center points to frogback.
Process one flowed point.
Face.dropPoint(pt) to get uv.
face.evaluateNormal(uv).
Figure out actual point on the frogback surface, using brep.dropPoint( pt )?
copy gem, using its normal or cplane or something, to align with frogpoint and its normal.
Repeat
The Pave circles (gems) appears to be closely connected to Rhino, Grasshopper, and physics engine Kangaroo2.
Kangaroo2 is written by Daniel Piker, who is responsible for numerous grasshopper circle packings with center repulsive force,
and boundary avoidance... Rhino 7 comes with all three programs. (I have not purchased Rhino.)
10052.17 In reply to 10052.14
Hi Michael, I agree, "Orient" will be the main tool when doing it the manually !
10052.18 In reply to 10052.13
Thank you very much Brian.
The Rhino video is nice, I agree - amazing programming work behind the tool.
It is a nice challenge to work out a method without the automated comfort
of a specialized pave tool, will have a look which way works best !
10052.19 In reply to 10052.16
<< ... Kangaroo>>
Being MOI´s greatest fan, I try to avoid to move into Rhino as I
prefer the minimalistic Zenlike aproach of MOI.
If I had dozens of projects in need of an automated pave tool I would
consider Rhino but so far I am confident to find a way within MOIs
capabilty ...
10052.20 In reply to 10052.19
Hi Tom,
not sure if this may help but in Blender there is an addon called Tissue that converts surfaces to hexagon mesh.
I've been using Moi to model and sending them to Blender via BMOI_Connector mentioned on this forum.
Anyway I have tried using an ico sphere created in Blender converting it to hexagon mesh and instance the gem stone onto the faces as shown in the photo.
On the left Sphere without smoothing, right with smoothing.
You can then bring them back into Moi via BMOI_Connector bridge.
Hope this helps.
Barry
Ps:this video may help
https://youtu.be/asBwqJKkFb4
EDITED: 10 Dec 2020 by BARRY-H
10052.21 In reply to 10052.20
Thank you ! That could be useful. Question is it may be worth the tine to get into Blender
as I never used this software before.
You can't wrap something on any volume/Surface with the Flow function ?
10052.23 In reply to 10052.22
Hi Pilou, Flow distorts the objects to adopt them to the targeted surface or curve,
But diamonds come with standarised sizes / carat and cuts.
10052.24 In reply to 10052.23
So maybe you can try Elephant! ;)
Hi Tom,
Here is a link to Bubble Chart, a dynamic circle technique example:
https://archive.nytimes.com/www.nytimes.com/interactive/2012/09/06/us/politics/convention-word-counts.html#Obama
The link is not a political statement, just an example of circle repulsion, like for electrically charged circles. (Underlying Javascript code can be viewed and copied in the brower.
The Bubble Chart link is from here:
https://github.com/d3/d3-force
So if the moveable circles are all the same size, and the boundaries and any internal boundaries are also charged, but non-moveable, the layout would settle down to some sort of hex grid, inside the boundaries.
It would also be nice to be able to add or remove a circle.
Haven't studied the code...
Well, it is 2d planar, not on a 3d surface.
10052.26
Tom,
Here is a test using the Node Editor. The qhull creates the diamond solid object from the outside point configuration of a triangle facet. The diamond is sent to a sphere point array that is orientated from center.
Qhull3d Ref:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.217
Wayne
EDITED: 17 Jan 2021 by WAYNEHILL5202
10052.27 In reply to 10052.25
Vasturiano has at least 2 other related github's, some with 3d features.
ps Wayne's node is cool.
10052.28 In reply to 10052.25
Brian, those bubbles are impressive - Grasshopper takes it one step further :
https://www.grasshopper3d.com/video/circle-packing
10052.29 In reply to 10052.26
Thats great Wayne, thank you I will have a look !!
10052.30 In reply to 10052.28
Still looking for javascript code for "repulsion" with the d3 code.
SteveHaroz and Mike Bostoc have d3 javascript code for many projects, some partially relevant to "repulsion:\".
They seem to be oriented towards Information graphics, (charts) rather than geometry.
https://bl.ocks.org/steveharoz
EDITED: 11 Dec 2020 by BEMFARMER
There are tutorial about d3-force here:
https://tomroth.com.au/d3/
Apparently d3 is "chart" graph software.
I'm thinking that a good programmer could adapt the js code to nodeeditor and MoI, to do the "Gem Paving".
Do not know how to apply the repulsion to nodes on a brep surface which is 3D, but locally relatively flat.
10052.32 In reply to 10052.31
Brian, it is impressive what´s out there as building blocks for any purpose.
I dont know how many jewellery designers use MOI as their tool, but certainly
they are there as proven by the GemArray script. Covering an area with Pave
(there is hexagonal and a square grid for the little pins) manually is quite a challenge.
Otherwise a programmed solution would need to be pretty sophisticated to serve its purpose.
10052.33 In reply to 10052.32
I spent a few hours looking at charting app, d3-force simulation.
Steve Haroz's ds-force testing ground program has interface sliders, for a number of the force choices.
Output is SVG graphics. It has a multiple sliders input panel, and is live.
The output would have to be converted to MoI planar geometry, and input would be a bunch of circles.
Maybe a MoI script could be done, with users able to manipulate the circles on the screen, with the mouse?
Or Nodeeditor?
There seem to be no boundaries, nor3d surfaces...
Maybe a bunch of anchored circles could form boundaries?
I read that there are 40,000 d3 examples. A bunch with d3 force.
One has the circles "afraid" of the mouse. Phylotaxis layout is a default.
Connecting Links, (lines, also called edges), is not needed...
Anyway, it was fun.
I think I will go back to some other projects now.
Show messages:  1-13  14-33  34-53  54-73  74-75
