Inset function unexpected behavior - bugs?
 1-6  7-26  27-37
10051.27 In reply to 10051.23
I think that probably the chamfer result is not generating the specialized analytic plane surface type for its result, but when you save and reload the file it does get an analytic plane there. That's what makes for a different result when you save and reload the file.
I'll see about tuning up the chamfer result to make an analytic plane when possible.
RD,
For the angles, look on my propositions.
10051.29 In reply to 10051.27
Thanks for your reply Michael.
Btw, I think that MoI has the potential to become the Zbrush standard for hard surface modeling. The word is spreading fast around. I'm personally extremely impressed by how fast I can create and model using it. It's amazing. The minimalist approach and UI simplicity is brilliant. As a side note, your Quads and Triangles (and N-gons) export function is almost perfect. I know it's not an easy problem to crack, but if you manage to do it, it will be a game changer for the industry. Thank you for creating this software! ;)
10051.30
Another suggestion, maybe add an angle option for the inset? Similar to the options we have when we extrude faces (Tapered). This way we would be able to control the result of the inset and the direction.
Thank you.
10051.31 In reply to 10051.30
Hi
You can
OFFSET edge of your surface
EXTRUDE negative
BOOLEAN diff
EDITED: 31 Dec 2020 by FINEMA
10051.32 In reply to 10051.29
Thanks RD I'm really glad you are liking it!
10051.33 In reply to 10051.30
Hi RD,
One thing that's difficult for that is handling it on curved surfaces. But it could be a possible option in the future for planar surfaces.
Message 10051.34 deleted 8 Dec 2020 by REDDIAMOND
10051.35
Many thanks to everyone that replied to this thread. Much appreciated!
10051.36 In reply to 10051.35
Hi RD, I've got a fix for the v4 final version so Chamfer will make an analytic plane when possible and that will then give the same result for Inset on it as saving to a file and reloading did.
Thanks for reporting the bug,
10051.37 In reply to 10051.36
Great! Thanks!
Show messages:  1-6  7-26  27-37
