Wrap Text along circle
 1-2  3-22  23-24
10048.3 In reply to 10048.1
The length of the line needed for the flow can be helpful.
Unwrap curve, for length can be helpful.
PI * diameter of circle, times a fraction, can be helpful.
Sometimes a surface (e.g. rectangle plane,) or two, are used, instead of lines/ curves.
10048.4
Smart very cool and helpfool. Must go to bed. Try it our tomorrow and give feeback, cheers, Mala. Kiss...
10048.5
Hi, I tried it out and I need that kind of operation. But I fail...hmmm´, sure it´s very simple. But also did not find a youtube video...Mala
EDITED: 10 Feb 2021 by MALA
10048.6 In reply to 10048.5
Hi Lara, can you please upload a .3dm file with the objects that you tried with?
Thanks, - Michael
10048.7 In reply to 10048.5
If one were to say your text is "standing up" on the base curve, then you might try to "lay it down"...
10048.8
Hello, thanks for your offer to take a look at the file.
What I did not understand in the tuts was: select the baseline of the font. I didn´t see a font baseline.
Best Mala
10048.9 In reply to 10048.8
Hi Lara (Mala),
The base line (or base surface), is created by the user to guide the placement of the text.
For your torus surface case, the base should (most likely) be a base surface.
So make a plane in proximity to your text. The plane is the base surface.
So the user may have to do some math to get the size of the plane rectangle, versus the surface dimensions of the torus, to guide where the text is "flowed" to. This is where unwrap of the two radii of the torus could help with plane dimensions times desired fraction. Also PI * 2* some radius could help.
Sizes of base line or surface, and placement at a base of the text, (Either the bottom of the letters, or the backside surface of the letters,) and point selected on torus, all influence the final result.
Like Burr says, the text can be lying on top of the base surface, or standing on top of the base surface...( or base line)
EDITED: 6 Dec 2020 by BEMFARMER
Think of the base surface and the text being made of stretchy or compressible rubber. Consider the text as lying down on the rubber sheet. The Flow command does some math, translations, scaling, rotation, alignment...
The base surface is stretched and curved to match a section of the torus, and the text stretches to match.
The user may want to cut out a section of the torus where the letters are to be located, and unfold the dimensions, (like unwrapping), to make the base suface, with a copy to be placed below the text. The target of the flow is the unwrapped section of torus. This would preserve some of the spacings.
The torus section could be a section of its outer semi-circular surface...
10048.11 In reply to 10048.8
Hi Mala,
Here is a picture of the required steps.
I hope it is of some help to your question.
Michel
Edit Pilou suggestion made me realize it was simpler to do it in one step, by unwrapping the whole torus.
You will get a plane of the size of the ring, and it will be easier to place ornaments on the surface.
Here is a second picture (the one with the grid) showing the process and a tip on how to move the seam of a torus.
Michel
EDITED: 6 Dec 2020 by VINC
Size: 548 KB, Downloaded: 49 times, Dimensions: 1543x540px
Size: 684.5 KB, Downloaded: 57 times, Dimensions: 4000x2500px
Another cool method!
Draw any surface on your cylinder (trim it)
Now you can Flow anything you want! :)
Maybe sometimes orient your letters + base Surface (here perpendicular) before the Flow! :)
Et voilà :)
EDITED: 6 Dec 2020 by PILOU
10048.13 In reply to 10048.8
Hi Mala, please let me know if you are still stuck.
10048.14 In reply to 10048.11
Very nice method.
Let MoI do the math whenever possible.
- B
10048.15
Hello,
not ready, but I checked the concept.
Thank you very much for your kicks...
Cheers, Mala
I do not often work with moi. But if I do, I cannot believe what you can do with it....my deepest thank you, Michael (and to all you, kind, friendly and constructive folks...)
10048.16 In reply to 10048.15
Hi Mala, is that going in the direction that you wanted? If not please post the .3dm file with the objects in it so I can show you where you need to click to control the alignment for surface to surface flow.
10048.17
Ok - i got problems with the 3-axis-cnc machine where I intend to produce the ring. The idea is to make it with a polyline of the font. I created it. But...I cannot bend it on the surface. Is it possible that polylines cannot be formed on a bended plane?
10048.18 In reply to 10048.17
Why not...
As you can see font is just curvated along the curve
so just take surface(s) as start and target and you will obtain perfect fit in all directions! ;)
EDITED: 8 Dec 2020 by PILOU
10048.19
Meanwhile it it clear. Tried it with a base line. Failed. With a base plane it works...
10048.20 In reply to 10048.18
Thanks Pilou. But it is not wrapped...or just not ready?
10048.21 In reply to 10048.18
...besides...how did you change so fast the text direction axis?
PS Speed is because i just record the "do redo undo"! ;)
So you don't see the mouse go to the icons and times to click! :)
Even that it's very speed naturally!
With the "Edit frame" (Options / Views (enable Show "Edit Frame") ) it's also very speedy!
Orientations of results depend of the place(s) where you click on surface(s)! (base & target)
And yes a "line" base can't be wraped on a surface curvated on 2 directions!
A "surface" base yes! :)
Show messages:  1-2  3-22  23-24
