Wrap Text along circle
 1-2  3-22  23-24
10048.23
Hi Lara.
Watch the video on the links in my message, they are based on the method that was published above.
In the video, instead of pressing the done key, I replaced it with pressing the right mouse button.
https://yadi.sk/i/Iqgz1wWfLr8ezw
https://yadi.sk/i/Ruspmko-matIqA
https://yadi.sk/d/ptjocdCUPLJh6A
10048.24 In reply to 10048.17
Hi Lara,
> Ok - i got problems with the 3-axis-cnc machine where I intend to produce the ring.
> The idea is to make it with a polyline of the font. I created it. But...I cannot bend it on
> the surface. Is it possible that polylines cannot be formed on a bended plane?
You can use Flow in either "curve to curve" mode where you have a base line and a target curve (both being curve objects, no surfaces), or "surface to surface" mode where you have a base plane and a target surface (both being surface objects).
It looks like you're trying to go from a base curve but your target is a surface and not another curve?
For applying onto a surface you will need to use surface to surface mode which means you will need to make a base plane instead of a line.
If you're still stuck please post the .3dm model file that corresponds to the screenshot.
Show messages:  1-2  3-22  23-24
