Wrap Text along circle
 1-18  19-24
10048.19
Meanwhile it it clear. Tried it with a base line. Failed. With a base plane it works...
10048.20 In reply to 10048.18
Thanks Pilou. But it is not wrapped...or just not ready?
10048.21 In reply to 10048.18
...besides...how did you change so fast the text direction axis?
PS Speed is because i just record the "do redo undo"! ;)
So you don't see the mouse go to the icons and times to click! :)
Even that it's very speed naturally!
With the "Edit frame" (Options / Views (enable Show "Edit Frame") ) it's also very speedy!
Orientations of results depend of the place(s) where you click on surface(s)! (base & target)
And yes a "line" base can't be wraped on a surface curvated on 2 directions!
A "surface" base yes! :)
EDITED: 8 Dec 2020 by PILOU
10048.23
Hi Lara.
Watch the video on the links in my message, they are based on the method that was published above.
In the video, instead of pressing the done key, I replaced it with pressing the right mouse button.
https://yadi.sk/i/Iqgz1wWfLr8ezw
https://yadi.sk/i/Ruspmko-matIqA
https://yadi.sk/d/ptjocdCUPLJh6A
10048.24 In reply to 10048.17
Hi Lara,
> Ok - i got problems with the 3-axis-cnc machine where I intend to produce the ring.
> The idea is to make it with a polyline of the font. I created it. But...I cannot bend it on
> the surface. Is it possible that polylines cannot be formed on a bended plane?
You can use Flow in either "curve to curve" mode where you have a base line and a target curve (both being curve objects, no surfaces), or "surface to surface" mode where you have a base plane and a target surface (both being surface objects).
It looks like you're trying to go from a base curve but your target is a surface and not another curve?
For applying onto a surface you will need to use surface to surface mode which means you will need to make a base plane instead of a line.
If you're still stuck please post the .3dm model file that corresponds to the screenshot.
Show messages:  1-18  19-24
