Dimension Tips
All  1-2  3-5
10047.3 In reply to 10047.2
Thankyou for the info and reminder Larry.
- B
EDITED: 7 Dec 2020 by BEMFARMER
Message 10047.4 deleted 12 Dec 2020 by BEMFARMER
Here is a slight modification of PointCoordinates script, with ( ) added to the clipboard coordinates. ( xnum, ynum, znum ).
This will be useful for Dim > Leader text.
To label the ( x, y, z ) coordinates of a point, with a Leader Dimension:
1. Turning off Grid Snap in the bottom bar is advisable.
2. Run the script "PointCoordinates4" and select the point. Hit OK.
(This places the 3 coordinate values in the clipboard.)
3. Run Dim > Leader. Select the same point, in order to Pick the leader arrow tip. Add the desired Leader lines by following the prompts. Add at least One leader line, (Two leader lines may look good.)
Press right mouse button, or hit enter, or Done, to bring up Text entry window.
Hit Ctrl+C to paste the ( x, y, z ) dimensions as text.
Hit OK.
The resulting Leader line text is: ( num1, num2, num3 )
which represents the values ( x, y, z ).
Well, it looks like I already posted this 2 years ago, so consider this an update. :-)
Another Well, see Larry's post #2 above. Maybe I should just delete this whole post...
EDITED: 18 Dec 2022 by BEMFARMER
Show messages: All  1-2  3-5
