I can't Boolean Diff these two solids
All  1-7  8-14
10043.8 In reply to 10043.1
Hi ed, please try attached technique. Let me know if you're still stuck.
(started earlier and finished up, late to the party!)
10043.9 In reply to 10043.8
@ Michael Why trim the middle little part?
Seems that works without it! If each curve has no overlap itself... :)
@ Burr thx! :)
@ Ed : nice one!
10043.10 In reply to 10043.9
Hi Pilou, I didn't trim there, that was a blend curve I put in since I sketched the pretzel instead of making it out of control points with alignment.
10043.11 In reply to 10043.10
Ok because that was writed "break" at these points! :)
10043.12 In reply to 10043.11
Yes, with the original description of it being one long unbroken curve, that case would need a break in that spot.
Thanks Michael -
Yes, that does work and I remade my model as below.
I first performed a Mutual Trim on my curve, took a short section shown in green, Mirrored it, Copied, and Joined to make the longer green & red chain. Then I performed a Sweep on each colored section and Boolean Union into a solid. Then I Flowed the design around the ring and Boolean Diff.
I made no attempt to match up the ends, as they are on the bottom of the ring, and this model is for rendering, not mfg. When I make the ring on a rotary table on the milling machine, the ball-nose cutter follows long continuous curves to produce the grooves. These curves match up on the ends for a seamless design.
Thanks again Michael, BurrMan & Pilou. I'll be making similar designs in the future and now I have a process for making the models.
10043.14 In reply to 10043.13
that's an awesome design. someone is going to be a very happy ring owner.
Show messages: All  1-7  8-14
