Dimension Error in Object?
All  1-2  3-6
10041.3 In reply to 10041.1
Hi wisty, yes just to clarify, the difference is because the size report in the properties panel that shows when you select an object is the "world axis aligned" bounding box size. Since your box is tilted with respect to the world x,y,z axes that makes for the difference in measurements.
10041.4 In reply to 10041.3
Thanks to both of you. That is now clear - the learning curve from paper and pencil (bad) sketches to MoI is steep.
I presume that If I want a specific sized item tilted, I need to build it square to the three axes and then tilt it. Or is there another way?
10041.5 In reply to 10041.4
Hi wisty, it can be simplest to build it along the world axes and then tilt it but it is also possible to draw it tilted directly. The Rectangle "3pts" command can be good for that:
10041.6 In reply to 10041.5
Thanks more for me to experiment with. I have a looooong way to go.
Show messages: All  1-2  3-6
