Moi and Rhino viewport display
All  1-6  7-18
1004.7 In reply to 1004.6
+1
i have used StudioTools, ProE, SolidWorks and i must say none of them has it.
1004.8 In reply to 1004.5
Maybe moi3d is a Rhino Killer...?
I tried Rhino 3D on the MACBOOK and I thought that it looked good,... but moi3d looked better on the PC.
That dashed all my hopes of moving all my workflow to the MAC....
I thought I could finally be free of Windos. . . the tyranny continues.
I think moi3d looks a lot like Alias Studio ver 2....no?
well in my mind it does, so I wanted to change the shaded view color from neutral grey to a rich indigo, is that possible?
1004.9 In reply to 1004.8
_Maybe moi3d is a Rhino Killer...?
(Nov 92 - Michael Gibson hired as an intern. He brought Sculptura, a mesh modeler that he had done as a class project.)
The the rest is history: http://en.wiki.mcneel.com/default.aspx/McNeel/RhinoHistory.html
I will personally buy into MOI phenomenon cause Micheals creativity + Very Good Support.
_I tried Rhino 3D on the MACBOOK and I thought that it looked good,... but moi3d looked better on the PC.
+1
Rhino guys say they doing some UI tests for V5...I think that it is extremely difficult to bolt on new technology to an existing product and maintain the same level of quality, performance, and usability... lets wait and see, NO SORRY I DONT HAVE THE TIME.
_That dashed all my hopes of moving all my workflow to the MAC....
You read my mind hehe. lets hope that Micheal sees the potencial of OSX and how much MONEY could be rolling into his bank account.
1004.10 In reply to 1004.9
You read my mind hehe. lets hope that Micheal sees the potencial of OSX and how much MONEY could be rolling into his bank account."
I agree
1004.11 In reply to 1004.8
Hi Nuri, you can change the shade color by editing moi.ini . It is usually located under
c:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini .
Close down MoI first, and then open up moi.ini in a text editor like notepad. Inside the [View] section there is an entry:
[View]
SurfaceUnselectedColor=255,255,255
This is an RGB value that you can change, so something like 200,200,255 would be kind of a lightish blue.
1004.12
Hi
First time posting here. I will be using a 3D LCD monitor called iz3d. It can display stereo images of DirectX driven renders. I want to model while seeing stereo.The choice of programs that use DirectX in their viewports that I could be using are: trueSpace, XSI 6, 3D-Brush (new ZBrush-type of program from Russia). From the discussion above, may I ask if I would be modeling with a DirectX display in MoI? I apologize if I have asked before in an email to the company... I have been asking about DirectX all over the place :)
Peter
1004.13 In reply to 1004.12
Hi Peter - yes, MoI uses DirectX to do the 3D rendering for its viewport display.
1004.14 In reply to 1004.11
> [View]
Hi Michael, is there some way to show selected objects in a different color than hovered ones?
Regards,
Marc
1004.15 In reply to 1004.14
Hi Marc, you can tweak those colors too if you want. In moi.ini these are available:
[View]
SurfaceUnselectedTransitionColor=255,255,208
SurfaceSelectedTransitionColor=255,255,128
SurfaceSelectedColor=239,239,0
The "Transition" ones are the ones for hovering. SurfaceUnselectedTransitionColor is the one used when you hover over an unselected object, and SurfaceSelectedTransitionColor is the one used when you hover over a selected object, where clicking it would unselect it.
They are used for more than just hovering directly over the surface though, they are also used in some other situations where clicking down would change the selection, like if you move over an edge.
1004.16 In reply to 1004.15
Thank you Michael for pointing out these adjustments. If I understand correctly these are only for surfaces, there is no adjustments for edges and curves hover state?
Regards,
Marc
1004.17 In reply to 1004.16
Hi Marc, you can adjust the color of curves and edges by using these 2 entries:
[View]
LineUnselectedColor=0,0,0
LineSelectedColor=255,255,32
Hovering for edges and curves works slightly differently than for surfaces. When you hover over a curve, the curve itself doesn't change color, instead there is a halo type glow that is drawn around it as an extra thing.
If your curve is unselected, the halo will be in the selected color, showing that if you click down that curve will become selected.
If you curve is selected, the halo will be in the unselected color, showing that if you click down that curve will become unselected.
So for curves, those 2 settings above control both the normal appearance and hovering.
1004.18
Thanks!
Marc
Show messages: All  1-6  7-18
