booleans in latest V4 version are not clean
All  1-2  3-17
At the end
Kill the piece of sphere
NetWork
Not sure if the surface from the network is the same than a sphere but that close fine the volume! :)
10039.5
Thanks for the explanation Pilou but I was hoping for an explanation why this does not work. If I move the sphere 1 mm up, the problem is solved, so there must be some intersection or so which generates bad geometry. I made sure the seams were on the other side, so that can't be the problem.
10039.6 In reply to 10039.5
I have a better solution! :)
Make a Boolean Merge! And kill volumes not wanted!
At the end the volume is a solid!
Michael will give you some explanations why the Boolean Diff don't works fine... ...
10039.7 In reply to 10039.1
Hi wim, it's just a guess since it will take a lot of work to confirm but I think it's probably the positioning of the bottom sphere's "pole" right nearby (but maybe not quite precisely on?) the intersection between the surfaces:
When I use Construct > Curve > Isect to generate intersection curves and zoom in to that pole closely it seems that the intersection curves come close to it but don't quite hit it directly.
The local area right around the pole of a sphere is kind of a sensitive zone because one direction of the surface is collapsing down to a single point. That causes some kinds of degenerate conditions for things like derivative and normal calculations. There is stuff in place to try and deal with those but maybe if you're just at the right spot nearby it, it can still be problematic.
10039.8 In reply to 10039.7
Just took a look and can confirm this to be the case...
If you go to the front view and rotate the sphere, just a bit, to get that seam edge away from the other object, the boolean works fine...
10039.9 In reply to 10039.8
Seam or not the seam that is the question! :)
EDITED: 22 Nov 2020 by PILOU
10039.11
Thank you all, it is clear to me now! it seams there was a seem problem anyway ;-)
wim
10039.12 In reply to 10039.11
The Boolean had an issue, though it's been seamlessly steered towards a funny bone...
I seem to like that....
10039.13 In reply to 10039.12
Although, i think my post was kindof misleading with the way i described it...
Michael DID give a description of what was causing the issue. It's NOT the seam edge.
I could "pole" the group to discover my mistake.
You could also rotate the spheres seam further into the base object and get good results too, so it's not really the "seam"...
But since we are making an avoidance move, i chose seam out, to get rid of the pesky rascal anyway....
Note to self.....
The more funny is that my solution of the Boolean Merge resolves all but you must make some manual clicks! :)
(2 in this special case)
10039.15 In reply to 10039.14
That seems to indicate the code to pole what part to throw away, is where the issue lay...
(See what i did there!)
10039.16 In reply to 10039.15
@BurrMan:
It's hard to explain puns to kleptomaniacs because they always take things literally.
¡¡ To be clear, I am NOT suggesting that anyone is a kleptomaniac !! (…its just a pun)
10039.17 In reply to 10039.16
Lol, Mindset....
I DO want to have a good time and be light with everybody... but i also forget that i am in a multi national setting, and i don't always get my point across....
And google ruins it, because they have a thing called "translate", which is NOT a translator, but a simple and often incorrect word exchanger...
But i'v learned to live with it.... it causes me to Take things, literally!
EDITED: 23 Nov 2020 by BURRMAN
Show messages: All  1-2  3-17
