booleans in latest V4 version are not clean
All  1-11  12-17
10039.12 In reply to 10039.11
The Boolean had an issue, though it's been seamlessly steered towards a funny bone...
I seem to like that....
10039.13 In reply to 10039.12
Although, i think my post was kindof misleading with the way i described it...
Michael DID give a description of what was causing the issue. It's NOT the seam edge.
I could "pole" the group to discover my mistake.
You could also rotate the spheres seam further into the base object and get good results too, so it's not really the "seam"...
But since we are making an avoidance move, i chose seam out, to get rid of the pesky rascal anyway....
Note to self.....
The more funny is that my solution of the Boolean Merge resolves all but you must make some manual clicks! :)
(2 in this special case)
10039.15 In reply to 10039.14
That seems to indicate the code to pole what part to throw away, is where the issue lay...
(See what i did there!)
10039.16 In reply to 10039.15
@BurrMan:
It's hard to explain puns to kleptomaniacs because they always take things literally.
¡¡ To be clear, I am NOT suggesting that anyone is a kleptomaniac !! (…its just a pun)
10039.17 In reply to 10039.16
Lol, Mindset....
I DO want to have a good time and be light with everybody... but i also forget that i am in a multi national setting, and i don't always get my point across....
And google ruins it, because they have a thing called "translate", which is NOT a translator, but a simple and often incorrect word exchanger...
But i'v learned to live with it.... it causes me to Take things, literally!
EDITED: 23 Nov 2020 by BURRMAN
Show messages: All  1-11  12-17
