Randomize spheres in a specified area
 1-6  7-25
10037.7 In reply to 10037.5
Thanks, but I really can't see how that will help me achieve what I asked for, since the array tools can't or doesn't seem to offer the random placement as I asked for in a specified area. Your first script is only selecting a percentage of what is there and that is all. I can select one or more simply by selecting them with left mouse clicks to get the same result.
_________________________
Don Cheke
Visit: Textual Creations
My Instagram: don.b.cheke
10037.8 In reply to 10037.6
Thanks Michael. I appreciate the lead.
Looks like the like doesn't work.
Size: 12.2 KB, Downloaded: 12 times, Dimensions: 400x182px
10037.9 In reply to 10037.1
Hi Don,
From what I have read, the random congruent sphere packing is not a trivial problem.
http://neams.rpi.edu/jiw2/papers/2013_04_JCP_QDM.pdf
A google search of "Ho-Kei Chan" shows several papers, but they involve containers which are skinny cylinders.
A google search of "Mhand Hifi" yields several papers, with actual Algorithm code.
10037.10
Hi
here un example from SKETCHUP and MS PHYSICS
( the first files is a animated GIF )
Methodology
in SKETCHUP
01 Create a sphere with a central point
02 Create a simulation with MS PHYSICS
03 Export center points only
in M.O.I
01 Rebuild the Spheres using the central points
Chri
EDITED: 21 Nov 2020 by CHRI
Size: 2.4 MB, Downloaded: 26 times, Dimensions: 353x325px
Size: 133.9 KB, Downloaded: 20 times, Dimensions: 1133x692px
10037.11 In reply to 10037.9
Thanks for the link Brian. Certainly not a read for the faint of heart. :-)
Don Cheke
10037.12 In reply to 10037.10
Thanks Christian. I don't know Sketchup at all so I would need to spend time learning it first and might consider that.
I did ask on a couple other forums and it looks like it can be done quite easily in SolidWorks with a basic motion study. I have access to that, so I will try in there first. The attached is from the SW forum.
Don Cheke
10037.13 In reply to 10037.12
Hi Don
I understand
SolidWorks is a great soft and easy to used
Chri
Size: 214.9 KB, Downloaded: 21 times, Dimensions: 1264x739px
Hi all,
Perhaps could you see this page github.com/schteppe/cannon.js
You could find a simple 3D physics engine for js with many samples like spheres falling.
During simulation, you could have the coords of spheres fallen.
I you find a script taking coords to place your spheres in MOI3D.
An idea perhaps to help you...
This idea could be used to place objects physically or narturally ?
Have fun !
10037.15 In reply to 10037.14
Thanks Phiro,
some more info about MSPhysics on Github:
here you go..............................................
https://github.com/AntonSynytsia/MSPhysics
http://sketchucation.com/forums/viewtopic.php?f=323&t=56852
Ken
If you want a complet tuto about MS Physics (for SketchUP) take a look at this ;)
26 little videos :) ps Sketchup is 10 times more easy than Blender! :)
EDITED: 22 Nov 2020 by PILOU
CHRI is a SketshUp specialist! ;)
ELse you can do that inside MOI :)
Populate your volume with Tangent cubes ...it's not a big deal!
Then draw a sphere at each center box!
script: /* Attribute a point at each center box's object selected*/ var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); var pt = obj.getBoundingBox().center; var ptfactory = moi.command.createFactory( 'point' ); ptfactory.setInput( 0, pt ); ptfactory.commit(); }
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2749.36
This one move an object(s) to points yet drawn
Must be existing something for attribute automatically an object to all points selected
but don't remember it for the moment! :(
Must be this one : copy to points :)
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
So copy the 2 files inside the folder commands
and make a shortcut "copytopoints" or press Tab and write Copytopoints...or COpyToPoints etc...
any letters you want except spaces
Have fun!
Damned seems there is a SyntaxError: Expected token ')' somewhere in this
this is the good one!!! (don't know where is the difference but... :)
script: /* Place a point at each selected object's bounding center */ var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); var pt = obj.getBoundingBox().center; var ptfactory = moi.command.createFactory( 'point' ); ptfactory.setInput( 0, pt ); ptfactory.commit(); }
You can also draw 2 Circles (constant radius) in a view
then now same radius circle but now Tangent !
Copy rotate at any moment in another view!for the third and upper...
At the end no problem to remplace all by spheres with the plugins seen above!
Like this you can simulate any natural falling bubbles! :)
10037.20
Thank you all for the input. It is so nice to be able to ask questions on a CAD forum and get so much help.
Don Cheke
10037.21 In reply to 10037.20
Of course the last trick is some manual and not so automatic! :)
And at the start draw the second circle vertically above the first one
for have a good start of propagation...
10037.22 In reply to 10037.18
Either script works fine for placing a point. (no syntax error)
10037.23
Hi
new files
Chri
EDITED: 12 Dec 2020 by CHRI
Size: 183.7 KB, Downloaded: 18 times, Dimensions: 487x467px
Size: 192 KB, Downloaded: 14 times, Dimensions: 730x593px
Size: 193.5 KB, Downloaded: 18 times, Dimensions: 1347x860px
10037.24 In reply to 10037.23
Yep that is the more easy for the moment! :)
If there are different sizes of spheres just take different color for each size!
(so for each familly of points...maybe successive imports... )
How is done the import from SketchUp ?
SVG, OBJ, DXF ... ?
10037.25
I just wanted to say thanks again. I did end up doing it in SolidWorks. Attached is a very low res animation.
Don Cheke
Show messages:  1-6  7-25
