Fillet problem
All  1-2  3-12
10034.3 In reply to 10034.2
unfortunately not working for me even lower than that ;(
10034.4 In reply to 10034.3
Hi albehany, it looks like you're using MoI v3? It seems to be working ok in v4, you can get the v4 beta at https://moi3d.com/beta.htm .
Message 10034.5 deleted 17 Nov 2020 by ALBEHANY
10034.6 In reply to 10034.4
Hi Michael, unfortunately even in v4 same problem with other model. i am trying to understand what cost this problem and how to avoid it when i am molding something. Thank you.
10034.7
Hey Albehany, it seems to work for me too over here.
Are you using circular as your Shape in fillet options?
10034.8 In reply to 10034.6
Curioussly works only one face side for me...
so
Scale 1000
Copy only one faces / Curves of the object
Rebuild all curves of this one side (one by one) 10 points
Make Planar 2 big rounded planes rounded faces extremities
Loft all the rest little curves
Shell all the faces ...Center Lines 100
Fillets 20 :)
Works fine! But maybe not the more speedy :)
EDITED: 18 Nov 2020 by PILOU
10034.9 In reply to 10034.6
Hi albehany, so for this last one the problem is that the surfaces are not smooth to each other, they range from something around 1 to 4 degrees off of being tangent.
This kind of geometry where surfaces are close to being smooth but not fully smooth makes things difficult for filleting. That's because fillets only naturally meet up on edges that are smooth to each other. When edges are not tangent to each other it means the fillet surfaces need to be extended and intersected with each other and that process becomes difficult at shallow angles. Surfaces that are at a shallow angle to each other when extended form something more like a "zone of overlap" rather than a crisp well defined intersection.
So the main thing to get fillets on this is to tighten up the construction so the surfaces are fully smooth where they touch rather than slightly creased. It's best to do this with your original curves before you construct things off of them.
10034.10 In reply to 10034.6
Hi albehany, so the underlying surface structure there looks good and is all smooth:
So maybe the problem is being introduced when they are cut to your final outline. What process have you used for cutting off the outer area?
10034.11 In reply to 10034.6
Hi albehany, here is a version where I formed one smooth sweep surface as a cutting object, and also scaled things up by 10 times in size. Having objects at a smaller scale can sometimes also cause problems. This should fillet more easily:
10034.12
Thank you so much guys for the help.
Show messages: All  1-2  3-12
