Fillet problem
All  1-9  10-12
10034.10 In reply to 10034.6
Hi albehany, so the underlying surface structure there looks good and is all smooth:
So maybe the problem is being introduced when they are cut to your final outline. What process have you used for cutting off the outer area?
10034.11 In reply to 10034.6
Hi albehany, here is a version where I formed one smooth sweep surface as a cutting object, and also scaled things up by 10 times in size. Having objects at a smaller scale can sometimes also cause problems. This should fillet more easily:
10034.12
Thank you so much guys for the help.
Show messages: All  1-9  10-12
