Inset question
 1-3  4-21
10029.4 In reply to 10029.2
Hi Mip, that's a cool idea to use "Expand" with a negative height!
Maybe the only potential problem with that is in a case like this, it's going to cut away this area by whatever height is set:
But if it's a small amount maybe not really a problem.
10029.5
Hey Mip, that's very clever! Unfortunately it did not work in my case.
@Michael, the zero width grooved version seems very handy- the one that produces the trim as a separate object. I can already see me using that, thanks.
I am attaching an example of why I am talking about this. The panel at the bottom right is a grooved inset that looks cool but it was not the intention. I wanted a submerged border around the perimeter. The Outwards option would mean that I would have to do the same treatment to the rest of the object(Impossible in this case), or I would have the panel extruding outside of the initial object boundary.
Size: 119.3 KB, Downloaded: 122 times, Dimensions: 1920x1200px
10029.6 In reply to 10029.4
Hi Michael and Nameless,
Thanks for the example.
And a groove width of 0 gets outwards while 1 repels the vertical face...
Is it related to the impossibility of entering 0 thickness ?
An inset without thickness is not too logical indeed...
@Nameless
I see. It really doesn't apply to your case.
Michel
Size: 219.8 KB, Downloaded: 56 times, Dimensions: 1845x271px
Have you an image Before / After of what do you want exactly ? :)
10029.8 In reply to 10029.7
@Pilou
A single click submerged border zone, using inset. This example is simplified for presentation- I need something that would work in curved surfaces and I do not consider sweeps to be a good solution. The Inset command has the potential to produce instant panelling, but is lacking this simple mode in my opinion.
Normal Groove don't make the trick ?
EDITED: 10 Nov 2020 by PILOU
10029.10 In reply to 10029.9
Hey Pilou, that creates a panel which is a tad smaller than intended and when put next to another similarly treated surface, it creates two "canyons" instead of one, if that makes sense.
Groove was eventually my choice out of necessity ;)
If you want the groove at any place just make it out of the surface
and reput it at any place and make a boolean Diff
Maybe Inset is not the only solution...
or this other one https://moi3d.com/forum/index.php?webtag=MOI&msg=9945.1
Here Fat Lines + Extrude + Boolean DIff
Fat Lines http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
10029.13 In reply to 10029.12
Thank you Pilou for the informative captures! Those solutions are too much work compared to a single click, plus they do not work as well on curved solids or imported subdiv models. I am looking at inset right now, which does exactly that (almost) ;)
10029.14 In reply to 10029.13
One click yes but you must draw something first! ;)
10029.15 In reply to 10029.14
One click yes but you must draw something first! ;) > You have something already, you want to create panel cuts. I mean, I am ok with us drawing spline curves to trim areas, but you should be able to jump from the trim to a panel gap around the perimeter without having to create bool objects for curved or even looped sweeps when you can select a face and just click Inset. It's ok for a cubical aligned surface, but not viable for relatively complex form with panels that wrap around it.
Do not get me wrong, I appreciate multiple paths to a goal and I learn from your flexible strategies that you often share in the forum, but this task should be simple in my opinion.
EDITED: 11 Nov 2020 by NAMELESS
10029.16 In reply to 10029.15
A new inset option! ;)
10029.17 In reply to 10029.6
@Mip,
All by itself it doesn't but if height and a groove width are set then it would be ok. That could then make the groove be the outermost piece.
10029.18 In reply to 10029.17
@Michael,
>Do you have an example where it would be useful to have the other variation?
Do you think my example is too fringe to justify an inset setting? Outwards is geometrically very close, but with an offset from the object's surface. So the "canyon" running around the perimeter ends up being level with the rest of the object when you wanted it to be submerged.
Something like this ?
And / Or other this ?
EDITED: 11 Nov 2020 by PILOU
10029.20 In reply to 10029.18
Hi nameless,
Well since they were so similar it helps for me to have an example of why the other one is needed too.
I don't think it will require an additional setting though, it should be possible to generate that if Thickness=0 is allowed with grooved mode. That should make the groove start right at the edge. That would get rid of this region marked in red, that should then give the result on the right that you want, is that correct?
10029.21 In reply to 10029.20
@Michael,
Correct!That's exactly right. I posted an example case some posts back just in case you didn't see it. Especially with a Create (SubD) workflow, it would be the dream to be able to trim, or even use existing surface seams and have inset create panels on some areas without having extrusions outside of the solid's initial volume.
Show messages:  1-3  4-21
