Inset question
 1-19  20-21
10029.20 In reply to 10029.18
Hi nameless,
> Do you think my example is too fringe to justify an inset setting? Outwards is geometrically very close, but
> with an offset from the object's surface. So the "canyon" running around the perimeter ends up being level
> with the rest of the object when you wanted it to be submerged.
Well since they were so similar it helps for me to have an example of why the other one is needed too.
I don't think it will require an additional setting though, it should be possible to generate that if Thickness=0 is allowed with grooved mode. That should make the groove start right at the edge. That would get rid of this region marked in red, that should then give the result on the right that you want, is that correct?
10029.21 In reply to 10029.20
@Michael,
Correct!That's exactly right. I posted an example case some posts back just in case you didn't see it. Especially with a Create (SubD) workflow, it would be the dream to be able to trim, or even use existing surface seams and have inset create panels on some areas without having extrusions outside of the solid's initial volume.
Show messages:  1-19  20-21
